which msd to purchase?
Old Jun 11, 2002 | 07:35 PM
James94LT1's Avatar
James94LT1
Default Re: which msd to purchase? (tntcorvette)
I have always ran a MSD 6AL. It has a built in rev limiter that you can use as a secondary one or program your stock one out. From there you can hook up all kinds of things. A retard box for when you hit the juice for example.
Get the wire connector kit and install is a snap!
Old Jun 11, 2002 | 07:47 PM
Nitro Junkie's Avatar
Nitro Junkie
You may want to look at the 6BTM (6462). Has an adjustable retard with a **** on the dash.
http://www.msdignition.com
Old Jun 11, 2002 | 08:21 PM
64FITanker's Avatar
64FITanker
I have the 6al on several vehicles. I find the one that you can adjust the timing does not work that well as the computer keeps returning it to what it wants
Old Jun 11, 2002 | 10:46 PM
Bluevette85's Avatar
Bluevette85
I just installed a Mallory Hyfire VI and it works fine. You will have the use the tach output from the box and bypass your tach filter.
Old Jun 11, 2002 | 11:16 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: which msd to purchase? (Bluevette85)
I really like my Digital 6Plus. Very easy to install. My factory tach works okay, it is a little behind the actual rpm's. I like the auto retard while cranking. After it fires up and hits 500 rpm's it automatically advances the timing. And it already has the two stage retard feature so you don't have to add anything when you put in NOX (not that I think you should do that to your engine, getting it hooked on drugs, shame on you).
To which msd to purchase?
