Stud Girdle
Old Jan 9, 2013 | 10:07 AM
howardjm's Avatar
howardjm
Default Stud Girdle
I want to replace my valve covers and want to know what are Stud Girdles? Many cover applications say some new covers will not fit with Stud Girdles. I have an 89 coupe
Old Jan 9, 2013 | 10:23 AM
John A. Marker's Avatar
John A. Marker
They are basically a bar that fits over the top of the rocker studs. The concept is that if you have a really high lift cam that would put additional force on the studs to bend or push up it will keep the studs in a straight line and help transfer any pressure up or to the side to the other studs when there is no pressure on them.
For a stock or slightly modified 89 it would be a waste of money. You would need taller valve covers and there is some question if the taller cover would fit under the wiper motor on the fire wall.
