**New Performance Optispark for your LT1/LT4!**
Old Jan 10, 2013 | 02:59 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Default **New Performance Optispark for your LT1/LT4!**
ProComp Optispark for LT1/Lt4
CHEVY LT1 10000 SERIES DISTRIBUTOR
OEM Replacement Distributor is designed for enthusiasts that are serious about performance.
precision tolerances, high strength and incredible endurance.
Under the brass terminals of the cap and rotor is an extremely accurate Optical eye which never requires adjustment.
The 1/2' steel shaft that spins the Rotor is guided by a sealed ball bearing and long sintered bushing.
This combination provides stable timing signals and spark delivery at any RPM.
1 year warranty!
Only $159.95 http://www.saccitycorvette.com/LT1-SBC-IGNITION.html
Old Jan 10, 2013 | 03:33 PM
STL94LT1's Avatar
STL94LT1
Sounds promising, and a great price!!
Old Jan 10, 2013 | 05:52 PM
Impala Balko's Avatar
Impala Balko
Whose going to be the first guinea pig.
Old Jan 10, 2013 | 09:36 PM
merlot566jka's Avatar
merlot566jka
The opti spark uses optical (infrared) leds.
The optispark does not have a hall effect magnetic field sensor.
Nice try.
Old Jan 10, 2013 | 10:13 PM
Glenno's Avatar
Glenno
Nice try.
Are you saying it won't work?
Old Jan 11, 2013 | 02:29 AM
merlot566jka
No. I am saying the information is wrong.
its like advertising bias ply Michelins for you C4
or AM radio....
Hall Effect Pickup is what the old school distributors used. And what some crank trigger systems use.
Yet this is not what the opti-spark uses.
The part may be fantastic and work really well....
At the same time when its advertised with incorrect information, I really start to wonder if they know what they are selling. Or if the manufacture knew what they were building.
Its like seeing a picture of an automatic rifle for sale and the sales pitch says "best revolver on the market"... I wouldnt be buying it...
Old Jan 11, 2013 | 06:12 AM
Glenno's Avatar
Glenno
or AM radio....
It is a step down in technology?
Old Jan 11, 2013 | 11:11 AM
rklessdriver's Avatar
rklessdriver
Old Jan 11, 2013 | 11:39 AM
93 ragtop's Avatar
93 ragtop
Well if I needed one, I would try it!!
Old Jan 11, 2013 | 11:52 AM
SacCityCorvette
Supporting Vendor
Nice try.
Hi merlot566jka,
We just copied the info right off of ProComps website. So we were not
trying anything. Glad you pointed that out, we will check on it.
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old Jan 12, 2013 | 07:10 AM
Pingman326's Avatar
Pingman326
Here is some more info I found on Ebay, I think it's the same Opti as the one posted here.
PROCOMP ELECTRONICS
PC10010D
GM LT1 DISTRIBUTOR
OPTI SPARK
We know all of you LT1 fans have been patiently waiting for a performance replacement for your 1995-1997 LT1 distributors.
Here it is!
(PLEASE VIEW 3RD PICTURE TO BE SURE IT WILL FIT YOUR APPLICATION
WILL NOT FIT SPLINE LT1 TYPE)See our other listings for that item.
This all new distributor housing is injection molded from a special material that provides extreme strength and high dielelctric properties resulting in less chance of breakdown causing a misfire. The terminal paths are encased in a durable epoxy compound for even more protection. The pickup is an advanced optical encoder, a different style of optical pickup than the OEM version. This new and improved pickup has been designed for reliability and stability through extreme RPM and conditions. The rotor is bolted to a drive assembly that is indexed to the shaft and is stabilized through the use of a large ball bearing assembly.
Old Jan 17, 2013 | 12:08 PM
SacCityCorvette
Supporting Vendor
One Year Warranty! Non race of course.
Old Jan 18, 2013 | 08:03 PM
mikem350's Avatar
mikem350
I think previous discussions turned up that all optis were made offshore by the same company?? And sold by Delphi, Delco and everybody?
Unbelieveable difference in price!! I used a cheapie off ebay, np!!
Old Jan 22, 2013 | 02:39 AM
SacCityCorvette
Supporting Vendor
Great price with a great warranty!
Old Jan 22, 2013 | 04:15 AM
corvetero's Avatar
corvetero
I've just bought my Petri's as spare part, I hope not to regret of it.
Old Jan 23, 2013 | 07:08 PM
SacCityCorvette
Supporting Vendor
And there is not much that insn't made offshore these day!
Old Jan 23, 2013 | 07:26 PM
dizwiz24's Avatar
dizwiz24
We have been burned by some very ****** opti sparks for our cars.
I hope this unit is high quality and not made in china crap.
This part can literally kill a corvette driver if it breaks down on them and strands them onthe side of a busy interstate.
Other drivers drive that crappy and inconsiderately that they are too stupid to identify a broken down vehicle. Even if its not on the road (ie. The berm), they will still hit it.
I hope this part works as advertised because we have been burned by other vendors.
I myself put in a remanufactured acdelco gen ii optispark that turned out defective. It took me 6 hours of labor to install/ reinstall a functioning replacemnt in place of the defective remanufactured ac delco optispark.
To **New Performance Optispark for your LT1/LT4!**
Old Jan 23, 2013 | 07:33 PM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
Originally Posted by dizwiz24
I myself put in a remanufactured acdelco gen ii optispark that turned out defective. It took me 6 hours of labor to install/ reinstall a functioning replacement in place of the defective remanufactured ac delco optispark.
How is your Optispark working? Any issues with the one in your Vette now?
Old Jan 23, 2013 | 08:14 PM
SacCityCorvette
Supporting Vendor
"This part can literally kill a corvette driver if it breaks down on them and strands them onthe side of a busy interstate."
The same could be said if a tire blew out, a ignition coil was defective or a ecu went out or any part on your Vette.
I know some of you have your doubts about this ProComp Optispark. I think if it were a product with a lot of defects it would be all over the internet. I'm sure every brand of opti (even GM) has its failures. Just saying! We do not manufacture the ProComp
Optispark, and are just a dealer for them. If we determine that they are not reliable or are of poor quality we will discontinue selling them.
Old Jan 23, 2013 | 10:30 PM
dizwiz24's Avatar
dizwiz24
The unit I installed is working fine.
I don't want to take away from the vendors new product release.
I hope it works out great. Thank you for supporting the c4
