89 hard brake lines
Navigator
89 hard brake lines
So as you can see in the title i have a 89 and the brake lines are getting pretty rusty where they go into the floor for the abs so i want to replace them. First i started looking into kits manily stainless and found classic tube which looking further there is no kit for 89 or 90 but there is one for 86-88 and some newer years which they do have diffrent size lines according to classic tube. From what i seen off of there site is the abs return line is diffrent size. So i am wandering if anybody on here can tell me that a 89 is the same as xx year.
I had also thought of making the lines myself from parts house straight tubing which i have done similar stuff before no problem but at one point i had a problem with a rebuilt master cylnder i found out that the fittings going into the master are metric. With that said i am guessing the entire system lines/ fittings are also. Can anybody comfirm that? The problem with the metric is nobody around me (that i know of / went to) carries metric. You outta see there faces when you ask for metric brake line fitting then they ask what car its off of and reply with a corvette.
I believe if you wanted to do the lines yourself you only need to match the tubing size, reuse the nuts (they've seen no weather) and make sure you have an ISO (inside out) "bubble" flare tool. The ABS control is certainly machined for ISO "bubble". If you demolished any fittings you would need ISO "bubble" M10X1.0 nuts except at the master where they use a different thread dimensions for front and rear to avoid a mismatch on the connections. I don't know why you would demolish them either. On the pipes at the wheel caliper ends the pipes are also I'm quite sure "bubble" and M10X1.0 would do them also. Might be nice for new nuts there.
Bubble is NOT like or similar to double-flare and it's a plus because its a single stroke flare vs a double flare which is a two stroke. Bubble is quite easy.
Bubble top - Double bottom
I would likely, depending on the condition of the pipes remove the retainers to the body,scuff/sand them(the pipes) and maybe coat them with an epoxy coating of some sort. I don't know how practical it is on a C4 but I've done it on others. I've never checked my brake pipes. Fuel pipes are fine.
- 1986 Original Owner -
Mike,
Dave is right about the ISO Bubble Flares. I rolled my own SS brake lines and got the bits from InLineTube.com. The flaring tool wasn't cheap, but I got the nice Mastercool hydraulic one as I intend to do many more flares.
I made six lines in total. There are two running from the MC to the ABS for Front and Rear inputs. There are two that run from the ABS back to the front for RF/LF calipers. There is one that runs from the ABS for the two rear calipers. The last one that runs forward along with the two MC lines and two front caliper lines is the fuel tank vent line. I also made this vent line to replace the whole bundle that runs along the driver side.
Ray,
That's some good looking tube forming there. Did you buy the complete Mastercool that does the Saginaw seal type as well as the Push-connect fuel lines. That's a very complete package that's both metric and SAE I believe. The interesting thing about the "bubble' is that it can even be accomplished with a very inexpensive bar/clamp type device.
Ray,
Mike,
Mike,
Greetings!
Nice post and info. I have a line replacement to do and need to ask you how and in what manner did you access the abs/lines going to same (Mine is an '88 coup). My thread link is posted below.
https://www.corvetteforum.com/forums...post1597341529
