Burnouts
Old Jun 12, 2002 | 12:25 AM
Red94Vette's Avatar
Red94Vette
Default Burnouts
Burnouts, Tirespin, and Smoke.
Sorry guys this has taken me a little longer than I thought. I successfully modeled tire temps (the real deal). Check it out, you can see the tire heat up in “stages”. This stair step is due to the hot rubber patch leaving the ground and not heating anymore and then when it makes its way back to the ground it heats up some more. These temps are the constant tire patch that is currently on the ground. As the heated patch makes it way around it raises even more. This is a 1,2,3rd gear rolling burn out. You can see that the motor bogged down to a steady RPM in 3rd.
I bet there isn’t another program like this one. :jester
I think I got a little carried away with this little aspect of my program but I wanted the best.
Now I will jump on this beta setup and we can test this thing out
:seeya
Old Jun 12, 2002 | 02:31 AM
Drewdog's Avatar
Drewdog
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Burnouts (Red94Vette)
:cool:
Old Jun 12, 2002 | 08:15 AM
jims_red_94LT1's Avatar
jims_red_94LT1
Too :cool: , quite the program you have there!!!
:flag
Old Jun 12, 2002 | 09:29 AM
Arisa's Avatar
Arisa
Default Re: Burnouts (jims_red_94LT1)
Great work!
Dumb question. What the "grass" at the bottom of the graph ?
Neal
Old Jun 12, 2002 | 09:38 AM
Red94Vette's Avatar
Red94Vette
Default Re: Burnouts (Arisa)
That "grass" is the rear tire position. I keep track of how many times the rear wheels spin over. It starts at zero degrees and clocks to 360 degrees and then starts over at zero again. Each peak you see is when the wheel traveled once around.
I use this to keep track of where the hotspot on the tire is located. Also it's cool to see how many times the wheel spins over compared to a sticky run.
For example, I can see that a certain tire compound spins over 4 times before another tire compound made one revolution.
:cool:
BTW, nice catch on the detail there. I know someone looked at it :lol:
To Burnouts
