Heat is on !!
Old Jan 13, 2013 | 04:29 PM
Qiken's Avatar
Qiken
Default Heat is on !!
Well its summer in aussie,and the last thing I need is hot air constantly blowing from the heater!!!
Does not matter if Electronic climate control in my 89 is on(regardless even if set at coldest temp) or is turned off..
I have noticed though the climate control digital temp indicator is"flickering" at times obviously indicating a fault,just wondering
if there is maybe a heater valve seized open somewhere?
Old Jan 13, 2013 | 10:32 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
Are there any fault codes? Does the green indicator light flash?
Old Jan 13, 2013 | 11:21 PM
ghlkal's Avatar
ghlkal
How to read HVAC codes on the C68 (should be the same for an 89)
http://forums.corvetteforum.com/1571731393-post3.html
Old Jan 15, 2013 | 02:11 AM
Qiken's Avatar
Qiken
Thanks,I'll see how I go
Old Jan 15, 2013 | 08:18 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Hot air means the temp door is stuck in the heat position. Could be a problem with control head, programmer, door motor or the clip from motor to door is broken.
Read this thread
http://forums.corvetteforum.com/1568603057-post3.html
If needed, you could remove the door motor and secure the door rod in the cool position, or see if you could gently pull/push the rod with motor connected.
The motor is just below ECM.
To Heat is on !!
