'93 Corvette Lagging
Old Jan 23, 2013 | 05:19 PM
rjschwar's Avatar
rjschwar
Yes, I have a vacuum gauge. I'll check it and report back.
Old Jan 23, 2013 | 09:58 PM
rjschwar's Avatar
rjschwar
Vacuum steady at about 18 at idle. When given gas goes down to about 15 and holds there. If I snap open the throttle, it increases for a second, then goes down to 15 for a second then settles back at 18.
Thanks,
Richard
Old Jan 29, 2013 | 01:54 AM
rjschwar's Avatar
rjschwar
Anything else to check? Change the fuel filter?
Thanks,
Richard
Old Jan 29, 2013 | 02:31 PM
desertmike1's Avatar
desertmike1
OK, so it sounds like you have steady Vacuum at the fuel pressure regulator Vacuum hose. Yet when you connect up, the fuel pressure becomes un-steady at a lower pressure. This might be a good time to change the fuel filter and retest the fuel pressure again afterwards..
I'll find some time in the next few days, and take a look at my FSM.
Old Mar 13, 2013 | 12:14 PM
rjschwar's Avatar
rjschwar
I finally got some time away from working on the house to work on the car. I got the fuel filter all changed out, and it had no effect. Actually I started to do it myself, and eventually decide that it was more trouble than it was worth so I brought it to Jiffy Lube and they only charged $20 to replace it as I brought the filter. Well worth the time saved.
Anyway, there was no change. Still lags in 4th gear, and in 6th under say 3000-3500 RPM . Also having acceleration falls off above 4500...still constant, just less pull.
I'm also now having an issue when I start the car and either back up then stop, or pull forward then stop the car really wants to die. If I don't give it gas it will struggle for 5ish seconds and eventually die. If I give it gas whether in gear or neutral it is fine. This only happens the first minute or so of driving when cold.
Just thought of something else. I sporadically get an EGR check engine code. Could this have anything to do with the issue? I also have alot of exhaust popping when decelerating which I have assumed is either the EGR or an exhaust leak that I haven't found somewhere.
Any other ideas?
Thanks,
Richard
Old Mar 18, 2013 | 06:26 PM
rjschwar's Avatar
rjschwar
Any suggestions on a next step?
Thanks,
Richard
Old Mar 27, 2013 | 01:00 AM
JAKE-SON's Avatar
JAKE-SON
I will take a look at the EGR Valve. You can replace it, clean it, or delete it all together with a TPiS block off plate. Valve could be stuck in the open position, causing it to have a vaccum leak. You are already getting a EGR code, so I would give that a look, especially if it is stock and has not been touched since 1993.
-Ryan M.
Old Mar 27, 2013 | 12:04 PM
rjschwar's Avatar
rjschwar
I'm heading out of town for a week but I'll take a look at cleaning it when I get back.
Thanks,
Richard
Old Apr 15, 2013 | 12:32 PM
rjschwar's Avatar
rjschwar
I pulled the EGR valve. It didn't appear to have alot of buildup, but I cleaned what I could, and made sure it opened and closed. I can reach in and push it open at idle and cause the engine to run really rough/die, so it doesn't appear it was stuck open. Still getting the lagging. I haven't yet gotten an EGR code but if I do I guess my next step would be to replace the valve? Should I test the solenoid somehow? What else could I look at?
Thanks,
Richard
