Head gasket question
What would be the optimum head gasket y'all would recommend for 1990 L98 with 97K miles?
Mine are blown and I'm looking for the best combination of durability and optimum thickness and diameter. IOW, not so thick that I have quench issues or potential problems with it blowing because of the bore diameter being large to point of insufficient material between it and some of the bolt holes, etc... (kind of an amalgamation of issues I read in the other threads)
Engine is bone stock and won't be rebuilt at this time. Ideally I could get a top end set including them.
On a stock engine, you will not gain or lose anything that would register on the dyno by changing gaskets.
My 85 cast iron block and cast iron heads had done 170,000 miles when i pulled the engine to fit the new 383. The heads/block and original shim head gaskets looked great still. Now that is 28 years!. the heads were crack tested and cleaned up then put on my 383 short block till i can afford some AFR heads they can easily do another 28 years !!!!!!.
Hint! hot water systems have a long warranty, they have a sacrificial element inside they give a warranty on how long that element lasts before electrolysis and galvanic action will eat the hot water tank.
Now consider your alloy head small block chevy, the radiator and heads are the ''sacrificial elements''. How long they last is how well your coolant and anti corrosion inhibitors are maintained,
that is why it is important to note the vehicle maintenance history.
Conclusion of today's science lesson
This is the correct gasket for this engine.
Joel
I'm a newbie to this. I need some help. I just had my ECT sensor changed. While the mechanic was bleeding the coolant, he notice the coolant fluid had few small boubles in the coolant tank. He stated this is a sign of the head gaskets going bad. Is this true?
