Maintance Questions...
Old Jan 16, 2013 | 06:53 PM
Snaps's Avatar
Snaps
Default Maintance Questions...
Info: 1990 6speed
Questions:
1: What kind of Fluid should be used in the Trans
2: What kind of Fluid should be used in the Rearend
Any tips when replacing the Thermastat, Flushing the coolant, and rearend fluid?
EGR block off plates... Removing the EGR and blocking them off would that require a tune?
Old Jan 16, 2013 | 10:34 PM
Churchkey's Avatar
Churchkey
Fluid brands vary depending on user.
If M6 remove the fill plug before draining the trans to insure refill.
No drain plug in the rear end. Warm the gear oil & suck it out.
Egr block will get a CEL code 32 (EGR), the only way to remove the CEL: Burn a new chip.
Old Jan 16, 2013 | 10:45 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
Originally Posted by DriftaVette
Info: 1990 6speed
Questions:
You'll get lots of opinions.
I use Castrol TWS 10-60. You'll find it at BMW dealers.
Old Jan 17, 2013 | 09:48 AM
Snaps's Avatar
Snaps
Thanks for the input.
Old Jan 17, 2013 | 10:43 PM
93Rubie's Avatar
93Rubie
Amsoil Syncromesh? is popular so is the Castrol TWS 10-60.
Some of use (me included) run Redline Lightweight Shockproof Gear Oil aka Smurf Blue.
Old Jan 19, 2013 | 08:42 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Info: 1990 6speed
Questions:
AMSOIL offerings for your 90 6 speed:
Tranny: AMSOIL Synthetic Synchromesh Transmission Fluid (MTF) (Product Code MTFQT)
Diff: AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 (Product Code SVGQT)
More than happy to get AMSOIL products for forum members at dealer wholesale pricing, about 25% below retail, via the AMSOIL Preferred Customer Program. Drop me a PM if interested.
Good luck with the fluid swaps!
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
To Maintance Questions...
