Well, I changed the fuel filter, air filter, plugs and plug wires and my engine stumble is still there. :( Last night I went WOT against a Suzuki GSXR 750 from a stop light and after a second, the engine cut out or bogged down (whichever you prefer). It caught right after the cutout and went right back to WOT. The only thing I haven't done is the fuel pump - do you think this could be the culprit? Also, does anyone know if any sensors could be causing this? TIA!
Re: Disconerting stumble still present... (cprgmr)
Considering that you had the ASR switched off, seems like the Throttle Position Sensor or the Mass Air Flow Sensor might be suspects (?)
Someone with more knowledge than I should chime in.
1st sentence says you did the fuel filter. If not, I would change jsut for good measure, especially if it has not been changed for 25,000 miles or more.
Re: Disconerting stumble still present... (Lone Ranger)
I guess I should've said fuel pump in the last part of the initial post (fixed now). The car is speed density, so no MAF changes possible. TPS is an interesting thought though... Any other suggestions?
Re: Disconerting stumble still present... (Red 86 4+3)
Is this bog happening when you first give it the gas, or is it when it shifts gears?
It never happens when I first take off at slow speed or at WOT - it's always a short delay and then it happens. I hadn't really thought about that, but it may be happening on the 1-2 shift (although only occasionally). I think this is the third or fourth time it's ever done it. Think it might be something with the TV cable?
Does this sound like your problem? Floor it, the engine revs, hits about 4000 rpm, drops to 3600 and then goes to redline? This is what is happeneing to me.
My Opti went about 2 months ago and when it was replaced (under warranty) I was told my spark plug wires were bad. Since the ignition was bad, it fouled all my spark plugs. I think it also fouled my O2 sensors. I am getting a SES light occasionally. I have had the code scanned and one O2 sensor is definitely not reading correctly. It took me a while to change wires, so I am pulling the plugs again tonight to see if they are fouled again. If the plugs are not fouled, it is probably the bad O2 sensors causing the "stumble". I would recommend having your codes scanned, just to see if something is there. Also check your O2 sensors.
Just something simple ?? Pull your throttlebody and clean the back side of the butterfly also I cleaned the "valve body looking plate from the bottom" after a cleaning it seemed to run alot smoother('93 m6)also have you done the vac>/vent kit on your opti ? When I installed mine I noticed it had a bit aof a stumble at idle>
maybe not but maybe!
Re: Disconerting stumble still present... (kkonen)
No, not exactly. What happens is that I go WOT and it takes right off then after a second, it cuts out for about a half a second then goes WOT again like there's nothing wrong. :confused: I just got done doing brand new O2 sensors when I did the converter and gears, so I don't think that's the problem (although anything can go at any time I guess). I dont' have the SES light but scanning for codes is a darn good idea. Something else - this never happened before I did the converter/tranny gears/tranny filter/diff. I'm wondering if I may have screwed up the TV cable or something when I put it back together? Maybe there's a check ball that's sticking? I just don't know...
Re: Disconerting stumble still present... (flubuyu2)
I haven't done the opti vent mod, but the opti itself has never given me any problems in the past. Also, when I did the intake leak last year, I cleaned the butterfly valves in the TB. I'm starting to wonder if it's tranny related as I had the TV cable disconnected when I pulled the tranny. :confused:
[Modified by cprgmr, 6:52 AM 6/13/2002]
I cant imagine what the TV cable could do to cause a hesitation. I was wondering if you were hitting your rev limiter when I ask if it was between the shifts. If it was me, I would put a fuel pressure guage on it to see if you could determine if you are loosing fuel pressure or not. I know mine will hesitate under hard acceleration (also after it is to the floor for about 1 second) it the gas is lower then 1/4 on the gauge.
Your problem sounds loke lack of fuel to me. You can get a fuel pressure guage and monitor the fuel pressue during acceleration. I had a similar problem and changed the fuel filter. It helped a little but changing the "sock" filter on the fuel pump did the trick. $22 at Pep Boys.
Re: Disconerting stumble still present... (MEBVette)
Pull your codes first to see if the ECM is trying to tell you something. You can alsways use the SWAG method (scientific wild a-- guess) if there are no codes. :lol:
Thanks for the replies guys - looks like I'll take a look at the codes (if any), fuel pressure and opti. I can't imagine that the opti went bad, it doesn't seem to have any problems 99% of the time I drive... :confused:
