94 low temp code
Old Jan 18, 2013 | 11:30 AM
zcmurray's Avatar
zcmurray
8th Gear
Default 94 low temp code
I get a Check Engine Light whenever I start up cold. The initial coolant temperature reading says 142 degrees when I start it up (it's obviously not at that temp). As soon as the coolant warms up and the temp gage moves off the 142 reading, the Check Engine Light goes off.
Anyone have a thought on how to correct this condition?
Old Jan 18, 2013 | 11:34 AM
STL94LT1's Avatar
STL94LT1
Check the coolant temp sensor (CTS) connection first. If ok, probably a bad CTS.
Old Jan 18, 2013 | 11:48 AM
zcmurray's Avatar
zcmurray
8th Gear
Is that the sensor on the water pump?
Old Jan 18, 2013 | 03:14 PM
STL94LT1's Avatar
STL94LT1
^^ Yes.
Old Jan 19, 2013 | 05:24 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Default any codes?
Did you retrieve the codes? If not, suggest doing and advising (paper clip is all that's needed, check sticky or do a search on how to read)..
btw, could be the ECT, or could be something else and the ECT, the code(s) will help determine.
Lastly, when engine is cold (overnight), digital dash's coolant temp and oil temp should be very close...
Old Jan 20, 2013 | 07:29 AM
zcmurray's Avatar
zcmurray
8th Gear
Pulled and cleaned the CTS plug. Works perfect now! Thanks for all the help guys! This is a great forum!!!!
Old Jan 20, 2013 | 11:09 AM
STL94LT1's Avatar
STL94LT1
Old Jan 20, 2013 | 01:49 PM
mrmtrtrnd's Avatar
mrmtrtrnd
Man I love a easy fix an happy ending, that doesn't happen often enough
Old Jan 20, 2013 | 07:26 PM
zcmurray's Avatar
zcmurray
8th Gear
Me toooooooo!
To 94 low temp code
