I did and you can but it depends on how clean you want the power to be. If you have ample pump for your application, good for you but if you want the ultimate, that would be it. That or if your wiring is flakey
did you see this link? http://forums.corvetteforum.com/c4-p...ale-items.html
FWIW my tuner still has my car, but it made 462hp on e85 60lb injectors and the racetronix kit with the 255 pump. It has no problem keeping up.
Keep in mind e85 needs about 30 percent more fuel then gas for the same output.
Do you have a link for this for a 91 with the entire package including the harness? I know its like $176 now didnt know if it was on sale as well? I'm just gonna order the kit with the harness included to be safe.
