Radiator Cleaning [part1]
Old Jun 13, 2002 | 02:24 AM
GlockLT4's Avatar
GlockLT4
Default Radiator Cleaning [part1]
Ok, since i hit 235*F in stop and go traffic today, and my analog was getting close to the "solid" area.. it was definitely time to clean the radiator.
BTW, i see why you guys complain about the 6 screws down at the bottom front of the radiator shrowd... what a pain in the ****! I'm also very surprised at the size of this radiator. I expected it to be MUCH larger :nonod:.
I haven't cleaned anything out yet. I'm going to pull the radiator tomorrow and it's gonna be air compressor time :D. Going to straighten as many fins as I can too. Also going to see about straightening fins on my A/C radiator to see if that will help make it blow cooler.
I think it's engine detail time too. :yesnod:
Here are the pics:
[Modified by Glock'94, 12:27 AM 6/13/2002]
[Modified by Glock'94, 12:28 AM 6/13/2002]
[Modified by Glock'94, 12:29 AM 6/13/2002]
Old Jun 13, 2002 | 02:41 AM
R23HTC's Avatar
R23HTC
Default Re: Radiator Cleaning [part1] (Glock'94)
How many birds did you find in that nest?
Those condoms hanging from there? :jester
Old Jun 13, 2002 | 02:44 AM
GlockLT4's Avatar
GlockLT4
Default Re: Radiator Cleaning [part1] (R94 LT 1)
i'm surprised i didn't find any birds, lol.
Sonic straw wrappers :rolleyes: :p:
Old Jun 13, 2002 | 03:25 AM
poppy's Avatar
poppy
Cruise-In III Veteran
Careful with that air.
Old Jun 13, 2002 | 03:27 AM
GlockLT4's Avatar
GlockLT4
Default Re: Radiator Cleaning [part1] (poppy)
yeah, not going to use a really high pressure.
Old Jun 13, 2002 | 07:19 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
You will be happy with the results. Those fins are very easy to bend be careful.
Old Jun 13, 2002 | 07:33 AM
jimbo10494's Avatar
jimbo10494
What gives!!! I removed my radiator last week, cleaned it, it was pretty dirty especially at the lower 8". However my coolant temp has not changed, at idle it goes up to 227 degrees, driving it hovers around 201-205 degrees, is this normal? I have the 195 degree thermostat. My fan is kicking on at 225 degrees.. I am concerned
Old Jun 13, 2002 | 10:13 AM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Default Re: Radiator Cleaning [part1] (jimbo10494)
You say it goes up to 227... any higher? If not, then it is probably fine. The fans start to pull the air through at 225. Before they kick on, there isn't much air flowing through so the ambient air around the rad just keeps getting warmer. If the temprature starts to drop as soon as the fans kick on, then you are getting good air flow through the radiator.
Old Jun 13, 2002 | 10:18 AM
Sharky Guam's Avatar
Sharky Guam
Default Re: Radiator Cleaning [part1] (92Shawnster)
Forget the hay for the bird's nest. I saw a Hooter's napkin with some girl's phone number written on it. I could not read the last two digits.
:lol: :lol:
Old Jun 13, 2002 | 10:43 AM
xzvs's Avatar
xzvs
My 88 also runs to 227 before the fan kicks on and that seems pretty normal- 195-205 highway.
Old Jun 13, 2002 | 11:47 AM
GlockLT4's Avatar
GlockLT4
correct :yesnod:
Old Jun 13, 2002 | 11:48 AM
GlockLT4's Avatar
GlockLT4
Default Re: Radiator Cleaning [part1] (Sharky Guam)
:lol: :lol:
:jester :jester :jester No wonder i've been having problems meeting the right girl. My car sucked up her number!! :eek: :eek: :D
[Modified by Glock'94, 9:48 AM 6/13/2002]
Old Jun 13, 2002 | 11:59 AM
NavyVet's Avatar
NavyVet
So, how come the Power Steering reservoir is clean? Did it come off mine while it's been in the shop? :jester
Old Jun 13, 2002 | 12:02 PM
GlockLT4's Avatar
GlockLT4
Default Re: Radiator Cleaning [part1] (NavyVet)
The power steering cooler has much larger fins. The transmission cooler that I added is what's sitting on the front of it. It is brand new, only 3k miles driving with it.
Old Jun 13, 2002 | 12:27 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
My car will stay around 177 to ~210 depending on traffic and outside temps. When i turn on the AC the temps climb to about 225 to 230 and stay there. I only use the AC when its over 90+ outside.
Old Jun 13, 2002 | 12:31 PM
NavyVet's Avatar
NavyVet
I was joking on the reservoir - the p/s fluid tank - black & shiny with no noticeable road grime. Hey, good luck. Cooling is a real pain here - temps run in the 105-115 range from June through September - except for the days when it really gets hot :D
Old Jun 13, 2002 | 01:48 PM
onedef92's Avatar
onedef92
Cruise-In VII Veteran
Cruise-In VIII Veteran
Be careful lifting the radiator off its mounts. I accidentally ruptured my A/C condenser last summer when performing this same task. :eek:
To Radiator Cleaning [part1]
Old Jun 13, 2002 | 03:35 PM
GlockLT4's Avatar
GlockLT4
Default Re: Radiator Cleaning [part1] (onedef92)
:eek: :eek: Since it's under pressure, I guess I didn't rupture it. No leaks.
Old Jun 13, 2002 | 03:54 PM
GlockLT4's Avatar
GlockLT4
part II:
http://forums.corvetteforum.com/zerothread?id=320792
[Modified by Glock'94, 1:54 PM 6/13/2002]
Old Jun 13, 2002 | 05:22 PM
YorkL8apex's Avatar
YorkL8apex
Glock,
Been trying to find out about a Tranny cooler for a while. Is that yours with the Mobil1 label on it? Would like to add one to my 91 if you could shoot me the mfg/model and where you got it. Neat install :cool:
Oh, by the way, the concrete part of the hiway is for driving, looks like you use the grassy part from those pics :lol:
[Modified by York67vette, 4:23 PM 6/13/2002]
