replacing opti spark with HEI dist.
Old Jan 22, 2013 | 03:09 PM
moenoyze's Avatar
moenoyze
Default replacing opti spark with HEI dist.
I'm carbing my 93 c4. I need some imput on mounting some kind of timing mark on or near front cover, I plan on using my stock balancer,7 in. The front cover plug that summit sells with timing mark on only fits 95 to 97. Can someone shed some lite on this ???
Old Jan 22, 2013 | 06:58 PM
93Rubie's Avatar
93Rubie
Your going to need to upgrade your timing cover to the 95-97 unit. The 96-96 unit will have a hole for a crank sensor but just plug that up with a freeze plug or similar.
I hope you don't intend to keep the factory gauges and other items like the ABS/ASR functional at all.
Old Jan 23, 2013 | 02:19 PM
mtwoolford's Avatar
mtwoolford
I suggest you buy an aftermarket crank hub that has a key way machined into it to ensure accurate timing.
Old Jan 24, 2013 | 06:46 PM
moenoyze's Avatar
moenoyze
Well I used my opti as a template, made a bracket out of 1/8" aluminum and fabed a pointer tab to show timing. Also did a clean up cut on my stock balancer will use 7" timing tape to mark degrees . Used a wire in #1 cyl. to find TDC. I have more work on other areas I'll let you know how it ends up.
Old Jan 24, 2013 | 06:50 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Clever guy. I like your methods. The wire trick to find TDC is a great/economical way to go about it. Nice work!
Old Jan 24, 2013 | 10:00 PM
Churchkey's Avatar
Churchkey
Close but no cigar. Close might be ok for a street motor
There is dwell time as the piston gets to top dead center.
Using a tool made from a strip of heavy flat stock drilled to bolt to the block across a cylinder & threaded in the center for a bolt to adjust the stop height. The piston is brought up & stopped against the tool adjustment bolt. When stopped the balancer is marked at the pointer. Back the engine up until the piston stops against the tool. Mark the balancer again. TDC is exactly in the center of the two marks on the balancer. Adjust the pointer to correspond to TDC.
Might be able to do it with a bolt screwed into the spark plug hole. Don't know, never tried it, never will.
Spark plug thread size is 14mm x 1.25 pitch.
Good luck
Old Jan 24, 2013 | 10:32 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
You can do what you just said, with a piece of stiff, bent wire.
Old Jan 24, 2013 | 10:51 PM
93Rubie's Avatar
93Rubie
Church Key hit the nail on the head. I forgot about that method. You'll be spot on with that. The timing cover plug with mark is just easier, but you gotta pay and buy it.
Old Jan 25, 2013 | 01:36 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
GM Performance parts used to sell all the parts, including an intake and timing cover, to convert an LT4 to a carb
sorry don't have the part #'s
Old Jan 25, 2013 | 02:00 PM
desertmike1's Avatar
desertmike1
Good luck
there are several degree's of Crank travel before, and after TDC were the piston does not move.
Old Jan 25, 2013 | 02:03 PM
93 ragtop's Avatar
93 ragtop
you may find some good info here.
http://ls1tech.com/forums/lt1-lt4-mo...hat-takes.html
Old Jan 26, 2013 | 05:29 PM
moenoyze's Avatar
moenoyze
thanks 93 ragtop that link is helpful.
Old Jan 26, 2013 | 05:56 PM
93 ragtop's Avatar
93 ragtop
your welcome!!
Old Jan 27, 2013 | 11:31 AM
moenoyze's Avatar
moenoyze
I know my method of finding TDC is crude , but it will get dynoed and the timing will be adjusted to max power. probably between 36 to 40 degrees total. That mark will be noted. My proform HEI has no vac advance, mech advance is all in at 2400 with total at 20 degrees. initial timing about 18 degrees. I dont think my methods will keep it from starting .
Old Apr 28, 2013 | 10:11 PM
moenoyze's Avatar
moenoyze
Well my carb & hei project is complete. 750 holly dbl pumper & GM gen II LT-1 carb manifold with proform HEI dist. On chassis dyno my 93 made 289 HP at rear wheels with stock torque converter. Before this change over it ran 13.30 & 40 at 102 MPH with stock motor and 4:10 gear. Went to maple grove to test. car bogged real bad, like hit your head on steering wheel. Still it managed a 12.96 at 108 MPH. Replaced stock converter with 10 in 3500. WOW ran 12.373 at 108.96 with 1.687 60 ft.With some more tuning may be 11.90 ???
Old Apr 28, 2013 | 10:29 PM
STEVEN13's Avatar
STEVEN13
You are saying 12.37 with 289 HP, 3500 stall converter, and 4.10 gears? What is the weight of your car?
That moving!!
My 92 makes the same RWHP (289) and went a 13.02 @106 mph (1.89 sixty foot) with 6 speed and stock rear 3.4x gears. In the process of having a 9" rear with 4.11 gears installed. I don't think I will go as fast as you-But I am hoping for 12.8-12.9 As soon as it is completed I will take it to the track.
Regards,
Steve
Old Apr 29, 2013 | 09:57 AM
moenoyze's Avatar
moenoyze
That moving!!
Regards,
Steve
car wt. with my fat a-- in it 3425 lbs. 700R trans shifts at 5600 and traps at 5800. tire size is 13.50X28.0 M/T. Rear is 12 bolt w/4-link. No tube headders just cast iron manifolds. maple grove time slip reads 60' 1.687 330' 5.020 1/8 7.857 MPH 86.67 1000' 10.305 ET 12.373 MPH 108.96. With EFI and stock coverter my 60' was 1.860. Steve if you can hook it with 106 MPH you should be mid to high 12's.
To replacing opti spark with HEI dist.
Old Apr 29, 2013 | 04:20 PM
STEVEN13's Avatar
STEVEN13
Are you making 289 hp now with the Carb or was that with the EFI? Would like to see some photos of the rear.
For comparison my car will also have a 4 link and 4.11 but with a 315x17 DR which measures about 26" x 12.5
Regards,
Steve
Old Apr 29, 2013 | 06:13 PM
moenoyze's Avatar
moenoyze
Regards,
Steve
Hey Steve, the 289 HP is with carb & stock converter. The bolt-in 12 bolt with 4 link is from House of Hook. It's a real nice kit, with some assy required. This kit is not for beginners. On this forum he has gotten bad feed back, I had to tweak a few things for a correct fit. It was not due to bad workmanship but variables in the cars from year to year.Others expect to take it out of the box and it will install itself. It worked exactly like Jesse said it would.
Old Apr 29, 2013 | 07:13 PM
STEVEN13's Avatar
STEVEN13
Cool. Good to hear!
Mine is being installed by a local racecar shop. If we are both making the same power-Maybe mine can go deep into the 12s. I would like to think a stick can go as good as an automatic.
Good luck with it!
Steve
