Need advice....
I am currently going crazy without my vette. As some of you know I thrashed my transmission this weekend at the strip. Finally got her into the 12s, even without 3rd gear, and now I have to wait till I can get a new transmission put in her. I am going to go with a Pro-built 700r4 fully set up for racing. I was very impressed with the phone call I had with him and I can still keep my existing transmission, to have it rebuilt or just use as a door stop.
As stated I am going crazy waiting and need to do something to occupy my time. I have decided to change the Dana 36 lub. I see the tag says use limited slip lub only. The guys at the local NAPA sold me a tube of gunk I am suppose to squirt in after adding regular gear lub. Well I decided to get the OK from you guys before trashing yet another component of my drivetrain.
What would you guys recommend? I have some leaky seals in the rear as well, so perhaps a thicker lub might stop some of the leaks. Any ideas. I have a bad feeling that once the new transmission is installed I am going to blow the rear out. For that reason I do not want to put a whole lot of work into the Dana 36. I will go with a Dana 44 once the 36 goes. Hopefully it will hold out for a while.
Also do you just remove the lower bolt to drain the rear?
Sorry for so many questions.
Thanks guys! :cheers:
iF there is a drain plug use it --if not suck the old stuff out with a pump--also add the additive first to insure you get all of it in.
[Modified by xzvs, 8:47 PM 6/13/2002]
