Backfire during acceleration on L98
Sorry, but you guys have more experience than me.
I'm getting about 2 or 3 backfires occasionally when I'm WOT at about 3k-4k rpm. It's probably been there since I got the vehicle, but I've only recently started to give it some hard acceleration to about 60 max to see how it's performing.
I want to say the sound is coming from the engine, not exhaust. I've read up that it could be any number of things, so can't fixate on one issue because just about everything in the engine has been said to be the culprit. Blown intake gasket, blown head gasket, bad timing, worn valve seals or springs, worn pushrods, bad EGR, bad spark plugs, bad wires, bad distributer, and a few others.
First... I just replaced the intake gaskets and it no longer leaks. That's out. And second, a compression test revealed between 160 and 170 on all cylinders, with the new plugs, wires, and distributer. It still idles fine and has good power. Also out.
I have a feeling it's the valve springs or timing because the backfiring is right in sync with the engine, and it only does it at higher RPM with full throttle.
Help and advice is always appreciated. Thanks.
The 85 had 24lb injectors standard and ran less pressure but you should have at least 30 psi fuel pressure, the electrical connectors on the fuel injectors can get damaged easily pulling them off by the wires .. a injector or spark plug problem will usually show up as a shudder/misfire. Fuel pressure, timing or valve lash as back firing.
Hope this info helps you
I have my original but checked out ok heads on my 383 engine and that has spun well over 6,000 rpm a few times by accident, i would say that your valve springs are not your problem...
Thanks for the quick response. I hope the weather's nice down there
) your not reading oil pressure off the dash. You need to hook up a fuel pressure gauge on the Schrader valve on the passenger side fuel rail to get reading. You can tape the gauge to the windshield while driving to see where it is at.Try opening the hood with the engine running on a dark night and see if you are getting any arcing from any of the plug wires.
X2 on that. If that information is accurate, something is way off. Confirm your fuel pressure. If FP is in fact correct (under the WOT load where the condition exits -checking at idles/driving around isn't checking), your plug wires aren't arcing (shorting to ground) and plugs are good, then I'd pull my rocker covers, crank the engine and look for a flat lobe (one or more rockers not cycling as much as the others).
misfiring can come from almost anywhere. Backfiring can only come from a path thru the engine back to the intake..like an intake valve thats stuck or burnt. If you say comp test were equal on all cyl, to me that is saying that you have a misfire. There is a small chance that a broken/bad spring could cause it at higher rpm where the weak spring makes the valve slow or late closing but it would also come with some clatter from the rocker flopping around waiting for the valve stem to rise...
The electrical is the heart & soul of the C4. Go thru the plugs on all sensors, inj, the ground bundle on the block and the jumper post hot wire stack.
If that yields no results then go to the ign and go thru it. A store brand ICM will cause this. Thats DELCO ONLY for the ICM. Cheap wires will also cause a misfire.
Another "esoteric" thing that can cause backfires is timing. The base timing could be off...which also puts you at risk for burning valves. The computer controls the timing. However, if the connector between the ECM and distributor is disconnected, you will only be running on base timing...also a bad thing. FWIW, a scanner will not show this issue since it only reports what the ECM is commanding regarding timing versus what is actually happening. The single wire connector is, IIRC, on the driver's side near the rear of the engine.
I'll check the plugs tonight in the dark, but I don't think it's the wires.
Still leaning toward the valve springs since it sounds right... I'm also getting a clicking through the covers so this might be the issue. When I was reading through other forums, another 85 had a similar issue, and it was solved with new springs after he tried everything.
Btw...if it's the oil pressure sender, it's not unusual for them to leak oil when they fail. Check for an oil leak at the rear of the intake.
Ended up buying a cheap light and changing the timing myself to 6* but it didn't feel right when I drove, so I started adjusting it between 2* and 8*. Finished with 8* because it's running much smoother in the mid rpm range. But, it's still backfiring at higher rpm.
Timing is off the board so I need to keep looking.
John, I'll take you up on that another day. Thanks.
Last edited by Ziggy91; Jan 25, 2013 at 08:55 PM. Reason: changed info because I'm dumb
You have to unplug the brown/black which disables the computer from advancing the distributor timing. Then set you timing. Turn off the car, plug the wire back in. Disconnect the negative cable from the battery to erase the code.
My engine never seemed to be affected by lack of performance and the wear was obviously visible when i removed the camshaft.
Valve springs are hardy things and when used with standard camshafts are never under much stress, usually the only symptom of "valve bounce" is a tapering off in performance rpm limiting no back firing and at way further up in the rpm range.
As for the fuel pressure 30 psi standard and i have an adjustable one on my 85, (45 psi the car really likes) any more and she will be way too rich at idle and yes the injectors can still work at around 60 psi but is that way over the top.
Get a gauge to measure your fuel pressure that is your number one most likely issue, be it a blocked fuel filter or bad fuel pump and or pulsator.
There have been several posts on this forum about backfiring, that were traced to bad fuel pressure and failing fuel pumps or bad fuel pump pulsator that was leaking .... see link or 101 projects for a corvette...
http://books.google.com.au/books?id=...lsator&f=false
