1984 questions
Question number one:
There is a coolant overflow reservoir, passenger side right behind the passanger headlight. It has what looks to be dirty water in it, and has no cap. However, the radiator itself has fresh looking antifreeze. Is this overflow reservoir necessary? Should I siphon the junk out and buy a cap? The car currently runs great as-is, and does not over heat in the slightest (then again the warmest day we have had since ive gotten it was 60 degrees).
Question number two:
My coolant/radiator fan does not turn on to my knowledge (it has yet to turn on since I got the car). My vette has gotten up to 235 degrees (as measured by the stock guage) and it didnt turn on, but it has never gotten past that temp yet. When the manual climate control slider is in any position BESIDES vent and feet, a clicking on and off sound happens every 5 seconds when the car is idling, and seems to be coming near the passenger side of the head near the spark plugs (to me near where the fan controller is (well i believe where it is). Now it doesnt make the clicking sound when it is driving ever. Nor does it make it while idling in vent or floor mode, but any other mode (AC modes and defrost) causes the clicking sound to occur. My theory is that those climate modes trigger the fan to come on, but since something is preventing the fan from turning on, it makes a clicking noise instead. Now I may be wrong. For all I know, the two problems are unrelated. Anybody know??
Fan switch in the pass side head that operates the fan may be faulty
Remove the connector to the switch and ground the wire .Fan should run
If it does , the switch is bad
If it doesn't the fan relay / wiring may be bad
Also need to apply power direct to the fan motor to confirm it actually works
If it does , the switch is badI disagree, from the drawing you posted, which is for the 84, the switch is rated for 238* F, this is usually +/- 5* if IIRC..233-243*..
I agree with the rest..
The coolant overflow tank doesn't exchange that much fluid with the cooling cooling system, so the fluid in the tank gets to looking pretty nasty. You can make it look like a new one by removing it from the car (two or three bolts) put some water and aquarium gravel in it and shake in all directions until all the rust and scum stains are gone. Refill it to the cold mark. You'll be surprised how long it stays clean. And yes, get a cap. They are cheap at any of the automotive chain stores.
Get it topped off at any AC shop.
Good news, update:
I got the radiator fan to start working properly. The culprit was low ATF. I topped it off with Dexron-II and while I was doing that, bam, it clicks on and has been working properly since. The transmission was about a quart short.
The AC blows cold, and now the clicking sound changed to an almost certain AC compressor cycling sound. It is only apparent while idling, and only happens when the manual climate control switch is on any position besides "OFF - Vent - OR Floor" Any settings in between, and the AC compressor makes a cycling noise.
I still have yet to siphon the dirty overflow coolant and get a cap. But that's easy lol.
The ATF dipstick had fluid on the very bottom of the stick. Enough fluid to not be dry, but low enough that it needed almost another quart to be near the full mark while hot.
It shifted smoothly before, and I notice no difference now that I added more fluid. An ATF drain and filter change would probably be a good thing to do, who's with me on that??
I noticed that they sell a "Wiring/Maintenance guide" for the 1984 vette @ http://www.crossfireinjection.net/catalog.htm
" Item Name: 84 Corvette Wiring/Maint Manual
Item Price: $0.00 *S/H Only*
Item SKU: DCS00014
Shipping USPS Flat Rate: $12.50
IN STOCK
Product Description This is a compilation of the C4 Parts Breakdown, Electrical Diagrams and Maintenance manual for 1984 Corvettes. Please note we ask that you just pay shipping and handling for this information. NOTE: 84 Corvette Only."
Does anyone have any info on this product? Is this the entire maintenance manual for the vette? Is it worth buying? Is it basically a FSM? I'm also planning on buying the Helm 1984 FSM here: http://www.helminc.com/helm/result.asp?Style=helm
Is that a good price?
Also is the Cheltons manual for these cars that bad? I basically just need a reference to help me with routine maintenance, such as draining the ATF from the pan and replacing the filter.
Thanks for the help.
Item SKU: DCS00014
IN STOCK
Chilton's manuals can be marginally useful if you have no other reference material. They periodically update the manuals to incorporate information on later models and sometimes they miss stuff. I sure wouldn't take anything in their manuals as gospel, especially if the hardware in front of you is different from what they are describing. This is especially true with regard to any wiring diagrams they include. GM, for what ever reason will change wire colors for a given circuit from one year to the next and Chilton (and Haynes) don't always catch the change.
The Helm FSM is your best investment. I'd check e-Bay too. manuals for that vintage show up pretty cheap these days, whereas manuals for 91 through 96 can be pretty close to the Helm price. In that case Helm is the better deal. Helm was the source for the original manuals and you will be getting new old stock book or a reprint of the original.
Our overflow is lower than the cap.
If the tank has no fluid in it when then expanded coolant is sucked back into the engine it could pull back in some air.
You always need a little coolant in that tank so the end of the line is kept under fluid.
