Where does this go?
Old Jan 29, 2013 | 08:09 PM
mxw128's Avatar
mxw128
Default Where does this go?
Anybody know what supposed to go on here? I noticed this today when I was wiping down the engine. The white nipple is in between an AIR pipe and a canister of some sort in the front of the drivers side wheel. I don't think its an evap canister, (I think that's in the rear), the canister has some wires going to it. The white nipple is on the drivers side ride above the steering shaft. It looks like there was maybe foam on it at one time. (sorry for the resolution, looks like it got resized when I posted)
Old Jan 29, 2013 | 08:17 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
Looks like the cags connector but that should be down on the drivers side of the transmission.
Old Jan 29, 2013 | 08:48 PM
mxw128's Avatar
mxw128
That's for manuals though too, right? Mine's an Auto...
Old Jan 29, 2013 | 09:19 PM
red89c4's Avatar
red89c4
i think that it is a vent. the foam was on it to act as a filter. you will need to get a matching opinion from someone other than me.
Old Jan 29, 2013 | 09:38 PM
96GS#007's Avatar
96GS#007
Year? Engine? Other pics? Work with us a little
Old Jan 30, 2013 | 08:04 AM
mxw128's Avatar
mxw128
Oops, your right, thought I had put that info in. It's a 94 LT1.
After a little more research it looks like this line runs between the electric A.I.R. pump and a tee from one of the check valves that is connected to the pipes coming off the exhaust manifold.
Old Feb 4, 2013 | 05:01 PM
mxw128's Avatar
mxw128
OK, I found out what it is... it's a vacuum bleed valve (#6 on the diagram).... now, the next question.. what does it do?
(I just looked back at the picture I posted before.. sorry for the **** poor quality, must have gotten resized when I uploaded... )
Old Feb 4, 2013 | 08:03 PM
mxw128's Avatar
mxw128
Got my service manuals today, and the answer to my question: according to it:
The "vacuum bleed valve, along with turning the air pump "ON" during cranking, helps prevent vacuum buildup within the AIR system which could prevent the integral stop valve from opening"
So it is a check type valve that allows air into the system but once pressure builds up, it doen't flow out. As suggested earlier, the remants of the foam on the valve was probably a filter to prevent any debris from entering the system.
To Where does this go?
