94 Check Engine Soon - Codes C12 and H48
I ran the codes with the paper clip method and keep getting C12 and H48 even after clearing out the codes for 1.7, 4.7 etc.
Thanks for your help!
Module 1 is the CCM
Module 4 is the PCM
Module 9 is the ABS/ASR
"Code 12 is standard throughout all three systems to indicate the system is functioning fine.
Code 12 will be displayed as C12.
If a Code 12 is not present, a larger problem exists and must be resolved.
All codes will be preceded with either an “H” for History (old) or “C” for Current (new)."
May want to read this
http://tech.corvettecentral.com/2011...trouble-codes/
but I am not seeing a 48 code in any module
