ride control system
Old Feb 1, 2013 | 09:24 AM
fradeninc's Avatar
fradeninc
6th Gear
Default 1991 ride control system
just bought a 1991 conv.; the ride control indicator light burns continuous. any advice or info would be helpful
Old Feb 1, 2013 | 10:28 AM
corvetero's Avatar
corvetero
Take away the bulb....just kidding you.
First step, check codes in the ECM
Old Feb 1, 2013 | 11:35 AM
fradeninc's Avatar
fradeninc
6th Gear
Default ride control light
thank you. i checked with the chevy. dealer parts dept. and was advised that the ride control module may need to be replaced at a cost of $2150? any advice!!!!
Old Feb 1, 2013 | 06:27 PM
corvetero's Avatar
corvetero
My car had the same problem and what the last owner finally did was disassembly the system and installed "normal" shocks.
Old Feb 1, 2013 | 06:37 PM
96GS#007's Avatar
96GS#007
Pull the codes. You can find out how to pull the Ride Control codes via the DIC in the Factory Service Manual or by using the directions in one of the dozens of threads a search will turn up.
In all likelihood it's one of the shock actuators.
Old Feb 1, 2013 | 06:46 PM
c4cruiser's Avatar
c4cruiser
Stay away from that dealer.
Old Feb 2, 2013 | 11:28 AM
fradeninc's Avatar
fradeninc
6th Gear
Default ride control problem
I ordered new shocks this am to replace the ones on it and disconnect the ride control system. Thanks to all of you. Will probably have more Q'S later on.
To ride control system
