1989 prom
Old Feb 10, 2013 | 08:24 PM
the blur's Avatar
the blur
Default 1989 prom
Was 1989 a 1 year prom, because they got rid of the cold start injector, and the next year they went to speed density.
Old Feb 10, 2013 | 11:22 PM
VetteVet86's Avatar
VetteVet86
I guess you could say that, however most calibrations changed from year to year anyway, even without any other changes.
I show 19 different calibrations that GM released for 1989 L98 Corvettes.
Check link below:
http://gearhead-efi.com/gearhead-efi...C%20lookup.xls
Once the spreadsheet is open, click the dropdown arrows on the column headings and select:
year = 1989
platform = yb
engine = l98
That will filter out all but the 1989 Corvette L98 calibrations.
Jep
Old Feb 11, 2013 | 12:36 AM
Cliff Harris's Avatar
Cliff Harris
The 1227165 ECM was used from '86 through '89, so the EPROM had to change in 1990 for the new ECM, if for no other reason.
The 1227165 ECM does have provisions for a MAP sensor, but I don't know if it was actually used on any MAP cars.
To 1989 prom
