95 Driver upper A-arm replacement - tips?
Old Feb 15, 2013 | 12:55 AM
corvette95's Avatar
corvette95
Default 95 Driver upper A-arm replacement - tips?
I need to replace my driver upper a arm and ball joint, can I do this with home tools or any tips . What would a decent shop charge for this service?
Old Feb 15, 2013 | 01:34 AM
vetteoz's Avatar
vetteoz
Originally Posted by corvette95
I need to replace my driver upper a arm and ball joint?
The bushes or the whole arm?
For $130 you can buy the whole arm brand new complete with factory ball joint and bushes ( the only way to get a OEM rubber bushes these days )
and just bolt it in yourself
See
http://www.corvetterecycling.com/198...controlarm.htm
Old Feb 15, 2013 | 06:06 AM
corvette95's Avatar
corvette95
I can only find a used arm for under $400(new) . I replacing whole upper arm only
Old Feb 15, 2013 | 06:14 AM
vetteoz's Avatar
vetteoz
Click on the link I posted above
Old Feb 15, 2013 | 06:25 AM
corvette95's Avatar
corvette95
I didn't see the link via iPhone , that's a deal if they still have some, I will call them when they open. Maybe vette2vette won't be too mad at me for canceling the order, they are really good used parts guys . Thank you for the link!!
Old Feb 15, 2013 | 06:37 AM
vetteoz's Avatar
vetteoz
I think so if you have to replace the whole arm.
By the time you price a quality ball joint ,possibly have to pay a shop to fit it if you can't do it yourself plus the cost of a replacement arm
factoring in having the genuine OEM bushings ..
Take the weight off the suspension ,crack the ball joint , undo two bolts and replace
Old Feb 15, 2013 | 01:35 PM
corvette95's Avatar
corvette95
Corvette recycling DID have the arm in stock for price advertised... thanks to vetteoz for saving me a few hundred bucks!!!! I owe you one!
Old Feb 15, 2013 | 05:07 PM
WW7's Avatar
WW7
If you have to do ball joints and bushings the $129.00 arm is a great deal , just unbolt one and bolt on the other...They must have a large amount of these in stock because they have had them for sale at least 2 years....WW
Old Feb 15, 2013 | 07:21 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
$260 for both UCAs is a heck of a deal.
Old Feb 16, 2013 | 02:15 AM
vetteoz's Avatar
vetteoz
All 4 for $400 is even better if you are up for a front suspension rebuild
Pressing a new ball joint in the lower arm can be a pain even with the right equipment
Old Feb 16, 2013 | 11:25 AM
corvette95's Avatar
corvette95
How do I separate the upper ball joint ? Do I need a spanner? And how do I seat the new arm and ball joint ? Thx!
Old Feb 16, 2013 | 07:22 PM
vetteoz's Avatar
vetteoz
How do I separate the upper ball joint ? And how do I seat the new arm and ball joint ?
A ball joint / tie rod splitter
Taper on the ball joint will reseat when installed and the nut tightened
Old Feb 16, 2013 | 07:58 PM
corvette95's Avatar
corvette95
Can I split the joint with other tools ? I don't have one of those .
Old Feb 16, 2013 | 08:04 PM
vetteoz's Avatar
vetteoz
You can smack on the bottom of the ball joint thread to see if you can crack it loose.
Doesn't matter if you destroy the threads seeing you are replacing the ball joint
Old Feb 16, 2013 | 08:52 PM
WW7's Avatar
WW7
Then get one... ...These can be had for less then $15.00, "Chinese of course"...WW
http://www.sears.com/shc/s/p_10153_1...30-115476585-2
Old Feb 18, 2013 | 10:02 AM
JoeUser's Avatar
JoeUser
I just use the pneumatic pickle fork attachment and my air hammer. But, if you don't have air tools, then one of those manual cheap use-once-throw-away pickle forks and a sledge will work (just watch your hands, it's real easy to glance off of the end of the fork and nail your hand).
Also, support the lower control arm slightly with a floor jack, and loosely secure the spindle with wire (coat hangers work well). Once the ball joint releases there's nothing holding that spindle, so the wire keeps it from flopping out and landing on yer foot...
To 95 Driver upper A-arm replacement - tips?
