Changed coolant hoses 95 Vette
This is one of the hoses that "T's" from the coolant tank to the radiator and then over to the throttle body.
Finished product....
I used a cut off wheel on my grinder and cut away the aluminum fitting that crimps the rubber hose to the tube. Note that under the fitting when you get the hose off there is a good base on the tube to slide a new section of 3/8" heater hose onto the tube and then clamp it.
I was shocked to find that the tube that goes into the "T" from the coolant tank was plugged and nothing could get thru.
I ran a wire thru the tube to clean it out. Then hit it with compressed air and then water. I did discover that the end of the tube nearest the coolant tank was restricted (manufactured this way) down to about a 1/16" diameter hole.
While I was at it, I by passed the TB. I rinsed out the coolant tank to get rid of all the rusty old junk that accumulated on the bottom of the tank. I got everything back together and filled the coolant up and ran the car. Damn, wouldn't you know it. The plastic spring loaded restricter inline to the heater core cracked where the hose slips over the fitting. I put in a temporary splice until I can get a new part.
I thought you could use some pictures of the lines with the crimped fitting off for your future reference.
It is not difficult to replace the lines. The cutoff wheel on my grinder made quick work of the aluminum crimp fittings I had more trouble trying to get off some of the GM squeeze clamps from the odd positions they were in.
And the inline part that broke on the heater hose I found out is called the Heater Control Valve. Most of the parts stores around me don't carry this item, but I found that Autozone has it in stock for $9.99. You might want to pick one up since plastic become brittle over time.
Here's a little trick you can use to improvd the looks of this setup. I've done it with all my hose clamps.:
1. cut the excess length off of the hose clamp.
2. slip a piece of electrical shrink tubing over the clamp band, leaving enough threads clear.
3. heat shrink the tubing.
4. turn the worm drive part of the clamp underneath the hose so it's out of sight, then tighten.
I'm not worried about "looks", just functionality. I'm just making sure their is no chemical reaction or something with coolant and brass I don't know about. Because that seems like the easiest solution to me for a "non-show car".
There's no reason why you couldn't but the idea with the carry it to the shop and have the "crimps" done was to preserve the OE appearance of the repair. There was a reference a few posts up that referred to brass or generic t's and that wasn't my idea when I mentioned having the crimps done! That's all - the idea was preserving the appearance of the part in the OP's first snapshot!
BTW "92ragtop" - that actually is a unique touch there.
