A/C elimination kit for -91 C4
Old Feb 18, 2013 | 04:45 AM
devilfish's Avatar
devilfish
Default A/C elimination kit for -91 C4
Anyone sell those, or can it be done with only a shorter belt?
Its for a -91
Cheers
Old Feb 18, 2013 | 07:05 AM
WVZR-1's Avatar
WVZR-1
Its for a -91
Cheers
TPiS does one for it. I always thought it a bit expensive but it does get the job done and is attractive enough.
http://www.tpis.com/parts/view/60
Old Feb 18, 2013 | 07:09 AM
vetteoz's Avatar
vetteoz
No
Anyone sell those,
http://forums.corvetteforum.com/1574453346-post3.html
http://www.gmpartsdirect.com/results...umber=10055890
Old Feb 18, 2013 | 09:03 AM
wilcar's Avatar
wilcar
The 10055890 listed above should cross to a dorman 34157. About $30 from amazon.
Old Feb 18, 2013 | 10:01 AM
devilfish's Avatar
devilfish
I ended up with the TPIS one. Im a sucker for *bling*..
Old Feb 18, 2013 | 10:23 AM
WVZR-1's Avatar
WVZR-1
I considered your "location" when I mentioned only the TPiS unit. Same belt, very straight forward install I believe and a one package shipment to consider. I've never used one but I've used similar products to accomplish the delete on other applications. There is the "bling" - which will likely be disguised in a "plain brown wrapper"!!
Old Feb 18, 2013 | 10:30 AM
devilfish's Avatar
devilfish
I have used the car with a broken A/C for 4 years. So that pice of aluminium is just dead weight atm.
This will clean things up, thanks for the tip..
Old Feb 18, 2013 | 05:42 PM
l98tpi's Avatar
l98tpi
Max G’s
I use the one from TPIS and works great. Had it for a couple years now and it is run under racing conditions without any issues. The one thing I will tell you is that you will have to shim it a little when you bolt it to the ac compressor bracket. No big deal at all, you will see what I mean when you go to mount it. I just used a couple of AL washers.
Old Feb 18, 2013 | 06:57 PM
devilfish's Avatar
devilfish
Thanks for the info
To A/C elimination kit for -91 C4
