Tune down my 355. Combo question
Old Feb 18, 2013 | 04:52 PM
devilfish's Avatar
devilfish
Default Tune down my 355. Combo question
Sorry to bother you with another of those ”combo” questions.
Story is that Im going to tune “down” my 355 and make a nice daily driver with good idle, that can pass sniffer test without any drama.
I have a combo in mind that I need some feedback on.
This is what I got to build on:
1991 vette 6spd
355 forge bottom end
Converted LT1 intake
Hooker headers to hooker front y-pipe to metallic “race” cat to rear magnaflow exhaust.
Plan so far is:
Cam.
CC XFI™ Xtreme Fuel Injection 260XFI HR13
210/218 .560 .555 ( 1:6 ) lobe 113
Or:
ZZ9 cam
212/226 .483 .520 ( 1:5 ) lobe 112
My exhaust is a narrow point, so perhaps the ZZ9 cam will work better?
Also tuneability is a factor here.
Heads.
Im looking at dart pro 1 alu heads:
180cc intake port, 64cc chambers.
With my pistons I will get 9.8:1 comp.
And the 180cc intake will be a descent match for the lt1 intake I think.
I hope this will make a mild, easy to tune, drama free daily driver.
Am I way off?
Cheers
Old Feb 18, 2013 | 07:08 PM
rklessdriver's Avatar
rklessdriver
If I had to run one or the other, I'd say the ZZ9 with 1.65/1.5 rockers....
I think the Howards PN 181145-12 would outrun either and be just as easy to tune.
http://www.summitracing.com/parts/hrs-181145-12
IMO, You need more compression... like 10.25 - 10.50 SCR.
The 180 Pro 1's will run fine on it.
Will
1991 vette 6spd
Plan so far is:
Cam.
Or:
ZZ9 cam
Heads.
Am I way off?
Cheers
Old Feb 18, 2013 | 07:53 PM
devilfish's Avatar
devilfish
So should i look for some 60/62 cc heads for the comp?
Old Feb 18, 2013 | 08:34 PM
THE 383 admiral's Avatar
THE 383 admiral
58/60 should bump you up.. with your factory pistons.. that ZZ9 cam.. I looked up some builds. That is a great.. cam. I agree. With the compression recommendation... to support that cam..
Old Feb 18, 2013 | 09:05 PM
devilfish's Avatar
devilfish
I use speedpro forge pistons.
http://www.jegs.com/i/Sealed-Power/8...oductId=755727
Edelbrock makes some 60cc heads:
http://www.jegs.com/i/Edelbrock/350/...ductId=2385061
But the runner size is 165, and lt1intake is 170, so I will have to port them.
Is worth the hassle to get the comp up slightly?
Old Feb 18, 2013 | 09:10 PM
devilfish's Avatar
devilfish
Or you got summits 62cc 170 heads
http://www.summitracing.com/parts/su...make/chevrolet
But I need to upgrade the springs on those heads with zz9 cam..
Old Feb 18, 2013 | 09:40 PM
THE 383 admiral
Ok forged is a excellent.. choice.. but are they true flat. 2 or 4 valve relief?
This will change your compression... a few points. Did you install a factory head gasket. A few point deviation. Can be gained or decreased.. here.
Without propper compression.. you will not take full advantage of a performance cam. That cam appears to be in the 10.0 & up bracket.
Old Feb 18, 2013 | 10:22 PM
rklessdriver
Neither of those heads will run with the Dart 180. IMO buy the Darts and have them decked to 60cc.... flat milling is .007 per 1cc... .028 off the deck will fix it up.
Will
Old Feb 18, 2013 | 11:31 PM
cv67's Avatar
cv67
St. Jude Donor '05
dont be afraid to mill a head
took my darts from 76 to 62 and seal just fine
Old Feb 19, 2013 | 04:03 AM
devilfish's Avatar
devilfish
4 vavle relief. I should be around 9.7ish with 64cc heads.
I havent decided on headgasget yet as im still choosing what route to go.
Old Feb 19, 2013 | 04:05 AM
devilfish's Avatar
devilfish
Will
Ah, smart
So what else needs to be done after you have milled the heads?
WHat comes in my mind is, custom length pushrods, shim the dis, .
Will the intake fit without moding it?
Anything else that needs to be addressed?
I dont whant to go crazy on this build, can you make a descent compromise with thinner headgasget?
Old Feb 19, 2013 | 09:02 AM
rklessdriver
No problems with the dizzy or intake only taking .028 off the heads.
Pushrod lengths need to be determined by a rocker geometry plot.... There is no way to know if your right or not unless you measure.
Has your block been decked? Any idea how far down in the hole the piston is?
You will be able to make some compression up using the VR .026 or Fel Pro 1094 .015 head gasket.
Just a quick look at compression.... FYI all my calculations are using the 4.030 bore, L2256 piston @ -6.1cc. 64cc combustion chamber. Piston .020 in the hole.
Victor 5746 .026 gasket = 10.10 SCR
Fel Pro 1094 .015 gasket = 10.38 SCR
Either of those will work fine with the heads @64cc.... Really depends on where the piston comes out in the block as to which gasket I'd use.
If it's .010-.015 I'd run the Victor Gasket.
If it's .015-.020 I'd run the Fel Pro gasket.
Compression with the heads cut to 60cc - everything else remaining the same.
Victor 5746 = 10.58
Fel Pro 1094 = 10.89
Here I'd go with the Victor gasket.
Will
Old Feb 19, 2013 | 10:06 AM
devilfish's Avatar
devilfish
Victor 5746 = 10.58
Will
Thanks for helping.
Block has not been decked.
I can measure the piston. You whant the distance between the piston and the top of the bore at tdc?
The victor gasget looks like a winner, 10.10:1 sounds like a good compromise.
Regards
Old Feb 19, 2013 | 10:19 AM
rklessdriver
Thanks for helping.
Regards
Yes the distance between the block deck surface and piston at TDC. Make sure you check inline with the wrist pin and center of the piston so you don't have to account so much for piston rock.
With an undecked block it should be around .018 - .020 in the hole.
No worries man. Everyone that contributes, including me, just wants to help.
Will
Old Feb 24, 2013 | 02:48 PM
devilfish's Avatar
devilfish
Will
Ok got the head off.
I measured between the center of the piston and a metal ruler that I laid flat over the block. I used a digital caliper.
It whas hard to get a consistent value, due the angel I held the caliper kept changing.
But it whas around .022 give or take..
I also saw that summit has these heads that might work better for me, and will pump up the comp to around 10.5:1 with 56cc chambers?
http://www.summitracing.com/parts/tf...make/chevrolet
And cam choise is most likely going to be the LPE211 cam:
211/219 .496/.525, with 1:5 rrs
What do you think?
Old Feb 24, 2013 | 05:11 PM
rklessdriver
With the 56cc head and the Victor5746 gasket your going to be 11.1SCR.
Will
Old Feb 24, 2013 | 05:58 PM
devilfish's Avatar
devilfish
Will
If I go with 56cc heads, plan whas to use stock type of headgasget..
To Tune down my 355. Combo question
