smoke from distributor cap
Old Feb 26, 2013 | 05:50 PM
darina's Avatar
darina
6th Gear
Default smoke from distributor cap
Hi there
I just got my car back from service , and 2 days later I notice a kinda white smoke coming from under the distributor cap
What the problem can be ?
Old Feb 26, 2013 | 06:17 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
electrical
Bearing going
Old Feb 26, 2013 | 06:19 PM
darina's Avatar
darina
6th Gear
Is it cheap fix
Old Feb 26, 2013 | 06:30 PM
Muffin's Avatar
Muffin
Did the car continue to run?
Old Feb 26, 2013 | 06:39 PM
darina's Avatar
darina
6th Gear
Yes its running w no problem
Old Feb 26, 2013 | 10:31 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Most electronic device run on white smoke.
Once the smoke is released, they quit working.....
Old Feb 26, 2013 | 11:34 PM
383vett's Avatar
383vett
Probably smoke coming from an oil leak behind the manifold. If the engine is still running, the smoke is not coming from inside the cap, it is sealed pretty well.
Old Feb 26, 2013 | 11:43 PM
Phat98's Avatar
Phat98
Yep, once the magic smoke gets out you can't put it back in...
Hopefully it's just a small oil or coolant leak.
Old Feb 26, 2013 | 11:45 PM
leesvet's Avatar
leesvet
is it 21 or older?
Old Feb 27, 2013 | 01:38 AM
darina's Avatar
darina
6th Gear
The car is 1988
The smoke is coming from under the cap
If its a leak oil is it bad ? I just spend 2000 fixing it this car end up priceless
Old Feb 27, 2013 | 02:20 AM
JrRifleCoach
Does the smoke have a odor?
Fuel, oil, electrical or steam?
Old Feb 27, 2013 | 02:30 AM
darina's Avatar
darina
6th Gear
It kinda smell like fuel.
Old Feb 27, 2013 | 07:44 AM
Muffin's Avatar
Muffin
This is where I was headed.
Old Feb 27, 2013 | 08:57 AM
ghoastrider1's Avatar
ghoastrider1
if it kinda smells like fuel, then you kinda need to stop driving/running the engine , untill you find out for sure. The burnt up Vette pics that pass thru here..well, find out ifs its fuel ..dangerous. good luck.
Old Feb 27, 2013 | 11:22 AM
mtnmanut's Avatar
mtnmanut
Old Feb 27, 2013 | 11:30 AM
BrianCunningham
Have you pulled the cap off yet?
How do the connections look?
Old Feb 27, 2013 | 05:12 PM
darina's Avatar
darina
6th Gear
No I didnt but ill do it today
Im not great at cars ill ask a friend to come and take the cap off
To smoke from distributor cap
Old Feb 28, 2013 | 01:33 PM
jimmymack's Avatar
jimmymack
St. Jude Donor '09 thru '25
Hi there
Means a new Pope has been elected. I suspect your car has magical powers and is now a blessed relic. You may be required to have it shipped to Rome immediatly to be displayed at the Sistine Chapel. Or the Corvette Musuem, same difference.
Old Feb 28, 2013 | 03:05 PM
cv67's Avatar
cv67
St. Jude Donor '05
Screwdriver will get the cap off look down the sides of the cap
Once off youll be able to smell if something was really fried. If all looks ok Id guess you got yourself an oil leak dripping off one of the cats maybe thats what youre seeing.
Old Feb 28, 2013 | 04:06 PM
Oklahoma_mike's Avatar
Oklahoma_mike
as much as I don’t like to condone going off topic this had me
