cooling fans
Old Feb 26, 2013 | 08:45 PM
no1vet's Avatar
no1vet
5th Gear
Default cooling fans
both fans are turning on well before the temp even reaches 80deg. sometimes sooner. i just replaced the opti..prior to figure' in out it was the opti i jumped both fan relays so they came on as soon as i turned the key(trying to help cool the engine)all was put back to norm. im thinking and hope'in the relays need changed. the temp. sensor was replaced aswell...any thoughts? Thanks
Old Feb 26, 2013 | 10:36 PM
vetteoz's Avatar
vetteoz
Originally Posted by no1vet
...any thoughts?
Year helps when asking questions; not all the same
Old Feb 27, 2013 | 12:13 AM
1986coupe's Avatar
1986coupe
Let us know what year it is.
Based on the fact that it has an opti I remember helping a friend with his 1994 once. We found out that under certain conditions the LT-1 engine will turn both fans on to protect itself. Before replacing parts, try to do some more troubleshooting.
Sorry that I can't be more specific.
Old Feb 27, 2013 | 12:33 AM
lozer's Avatar
lozer
is your defroster on?
Old Feb 27, 2013 | 04:37 PM
no1vet's Avatar
no1vet
5th Gear
Default 1992
1992 is the year...(my bad) the air and defrost are off. im thinkin of replacing the relays and see what happens..thanks for the reply's
Old Feb 27, 2013 | 04:48 PM
vetteoz's Avatar
vetteoz
One way to waste $$$
Unless the fans run as soon as you turn the key on then SOMETHING is causing the relays to operate;
they don't have a mind of their own.
You need to find out WHY the fan relays are being operated
Old Feb 27, 2013 | 04:51 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
both fans are turning on well before the temp even reaches 80deg. sometimes sooner. Thanks
If the fans are sometimes off and just come on sooner than they should, the problem isn't with a relay.
The scenario you described in your first post tells you the relay is working ok.
Old Feb 28, 2013 | 09:59 PM
no1vet's Avatar
no1vet
5th Gear
Default problem solved
i ran the car with the heater on thinkin there may have been air in the lines since i just drained all the antifreeze from changing the opti. dist. and after 15 minutes the fans work properly once again. thanks to all that gave me advice..
To cooling fans
