Antenna (motor) not working
The original Bose stereo in my 85 c4 was working fine. It stopped working about 3 days ago. The antenna does not go up when I turn the radio on. I am getting no sound from the speakers. I am wondering if the antenna has to be up to get the radio to even make sound. I do hear the motor on the antenna click...but no movement of the antenna. Has anyone had this problem? I do not want to go into the dash if possible. Hoping that it is just a loose wire or bad motor instead of tearing into the radio. The digital readout of the radio works fine.
CJ
CJ
You should get some reception with the antena down. I got lucky and mine is stuck up! They make an aftermarket antena repair kit and motor(if needed) for your 85.
Nows the time to upgrade that 28 year old stereo and speakers into the 21st Century!
I thank you for your reply. The bose is putting no noise out although gauges say otherwise. I here a clicking noise at the motor for the antenna. Does the on switch for the bose an
d the antenna have to be raised to just get static? I would possibly upgrade to a good stereo with a subwoofer. Any suggestions? Such as mounting tips for the sub and "clean wiring".
cj
cj
[QUOTE][I would possibly upgrade to a good stereo with a subwoofer. Any suggestions? Such as mounting tips for the sub and "clean wiring"./QUOTE]
I went with Alpine Doubble DIN and speakers and no subwoofer. Not sure about how much room you have in your pre-90?
CJ
CJ
There are replacements that are fairly inexpensive and not too hard to replace.
Although some radios sensitivity is higher than others and will pickup some stations without one, most radios need the antenna in order to receive any radio stations. Especially FM.
Turn the radio on and go to the back of the car and see if you can pull the antenna up by hand.
Unplug the antenna relay temporarily until you replace the mast.
You'll have to remove the rear hatch panel. The relay is on the drivers side.
hmmm.............sounds like it may be the problem...this all started when i got something out from the hatch area the other day..........the courtesy lights in the doors have also stopped working............these cars are so darn finicky..........Very addictive though!
I like your setup. How did you get around the heater sliders and stuff. Is there and installation kit available. Still thinking about a sub.....but then again I might not here the motor rumble...lol
CJ
CJ
The antenna is a simple thing maybe the large gear just needs to be greased and a new mast fitted which are still available from corvettecentral and still quite cheap.
