I installed the drivers side upper a arm today that I had been dreading, ending up being an east job. Tomorrow's list calls for passenger side front lower a arm install. Anything or words of wisdom to share? 95 coupe.
Watch the spring, its under tension. Make sure your torquing down the fasteners for those control arms, sway bar links, at trim height.
If you don't know what that is you should pick up a FSM.
The bushings twist under load of the suspension moving. Trim height is where the car rests most of the time. If you torque the bushings down at full rebound or below that well, not a good idea.
He's saying NOT to tighten the bushing bolts until you get the arm approx where it will live with the car on the ground. If you Torque it down with it in full compression or rebound, that may/will limit its travel and effect the suspensions ability to respond, it'll act bad.
Top arm was cake, wasn;t it? Lower is not too bad...'cept for 1 bolt.
Now. go find a 4 wheel laser alignment shop.
I understand the concept of what your saying about dont toque it down under too much or too little load but cant see it in my head, I am sure when I begin the job it will be evident that ya'll are talking about. Is there a measurement I should take before I take off the a arm like front shock top to bottom of spring with load off suspension or something?
With all the suspension put back together ,hanging free, the arm will be at full travel ( shock fully extended )
You need to put a floor jack underneath the arm and lift it up to " normal" ride height ( mid travel ) before torquing up the bolts
so it sounds like a measurement from the bottom of control arm to floor (drive on lift) before I took it loose would help me get it back close to stock position. Thanks!
So long as the floor doesn't move ;ie you jack the car up higher.
I would be more inclined to measure to a point on the frame then it doesn't matter what height the car is
]So long as the floor doesn't move [/B];ie you jack the car up higher.
Doing this proceedure in Ca requires the shops to measure from the frame...
IDK how the 95 FSM is but the 93 FSM has the trim height page on 3-21 and 3-22.
The points for the front suspension are:
From the center line of the lower control arm inboard end to the lowest inboard point on the ball stud housing.
This is the Z measurement; spec is 56.5mm for a FE1 coupe. 54mm for FX3 and Z07. +/- 6.4mm
Your car might have softer springs if FE1 or FX3. Go with your book.
