Ball joint question
Old Mar 3, 2013 | 08:12 AM
hobbs vette's Avatar
hobbs vette
Default Ball joint question
After reading many threads I decided to install new ball joints myself. Every thing went fine until the last one (lower). It went in crooked but did straighten up eventually. My question is, will it be OK? Will it come loose over time?
Old Mar 3, 2013 | 08:25 AM
DucXL's Avatar
DucXL
I have a question for YOU.Did you use a ball joint PRESS? Or a ball joint fork? I am looking for a proper press to initiate my replacement
Old Mar 3, 2013 | 08:32 AM
ex-x-fire's Avatar
ex-x-fire
Did it go in hard all the way or did it fall it quick at the part of pressing?
Old Mar 3, 2013 | 09:51 AM
hobbs vette
I used a ball joint press, looked like a large 'C' clamp. It went in hard all the way until the last little bit pretty much same as the other side which went in straight but very hard. I didn't use a impact gun. I used a breaker bar about 16" long, both were a struggle putting in.
Old Mar 3, 2013 | 10:11 AM
ex-x-fire's Avatar
ex-x-fire
I'd say your ok then, if it got easier near the end then the hole is egg shaped.
When I have that problem of a ball joints starting crooked, I'll loosen the press alittle & smack the press w/ a hammer in the right direction.
To Ball joint question
