Dynoed LT4. Poor result
More background:
I only put Chevron '91 in it. I've been commuting to work again for a month now, so there's no older left gas in the system.
Fuel pump is only a couple of years old, ditto plugs and leads.
I recently spray-cleaned the throttle body, seemed to be working fine.
Opti and wp were new on the car when I got it 6 yrs ago, at 81k. I have a new GMPP pump sitting there ready to go, I will order an opti, fuel filter and put them all on (my hunch is I've had opti problems for while now).
I'll see about a different dyno tune then, and post. I did not get any a/f info at this place, it was purely a cheapo dyno day.
I wanted the FIC injectors anyway, I will do that next.
I wanted a hotcam anyway, I will do that and springs next.
I will then either have a big smile on my face or will have the car in the For Sale section
Locally I'd hope to see 103-107 mph from a stock lt4 if I had one.
I did 12.93 at 110.30mph at the strip with a .270 reaction time!
However it doesn't help the op at all. Boasting about your numbers isn't helping him figure out if there's something wrong with his car. If you want to help how about you go and dyno your car back to back with his. I wouldn't be surprised if you hit 20 hp more on THAT dyno and that his car still traps well.
Op take it to the track. Reaction time means nothing. Mine is usually in the 7 second range. Just check your mph.
take it to the track & see what mph it posts...very telling of hp levels in real terms
I'd say if there was not noticeable misfiring during your run, then you have a compression issue or someone really did replace the LT4 with an LT1 at some point. Have you looked at the rockers?
Do some runs to get your MPH.
I disagree with whomever said trap speed should be 103-107. My stock LT1 with ONLY muffler eliminators and x pipe traps at 105 pretty consistently. Go ahead call BS on this, you call all you want. Doesn't change the fact it is the truth.
LT4 should be a few MPH quicker depending on car/track conditions. List your DA at the track you go to.
The local track to me at best is around 1400 or so in the spring or fall. At least when I have been there.
And no, guys it's not a bloody LT1
- I'm not that daft
