C5 brakes
Old Mar 8, 2013 | 11:10 AM
383vett's Avatar
383vett
Default C5 brakes
Somewhere I heard that C4s can run C5 brakes in back to better hold the car on the line when footbraking. Anywone done this. Do 10x15 wheels still fit on the back? Thanks, Willie
Old Mar 8, 2013 | 05:00 PM
leesvet's Avatar
leesvet
I've heard of that but I think the proportioning valve is part of the deal as well.
Another 'fix' you can think about is a brake lock.
Its a simple valve with a handle in the cabin that you flip when you step on the brake. This "locks" the fluid down so the brake is held even after the pedal is released.
For holding the line, I'd set up fronts to be on the lock so the rears could be free to turn...
time it right and you flip the lever to release the front brake and C-Yaaaaaaaaaa ! yer outta there
Old Mar 9, 2013 | 01:57 AM
383vett's Avatar
383vett
Thanks Lee. I already have a linelock for locking the front brakes during a burnout. I do set it when I am staged, but front brakes and skinnies don't do much when the big meats in back are trying to push the car past the line. I need bigger brakes in back to keep the rears from turning. Here's the linelock in action.
Old Mar 9, 2013 | 02:07 AM
Crepitus's Avatar
Crepitus
A popular RR setup is to use the front J55s on the rear. DRM can make the brackets. They are not listed on the web site. There was a recent thread iirc on the ax rr board. I'll see if I can dig it up.
http://forums.corvetteforum.com/auto...ad-racing.html
Old Mar 9, 2013 | 08:10 PM
383vett's Avatar
383vett
Thanks for the homework. I'll look into it. I don't think 15" wheels will fit with the J55 brakes, but it's worth investigating.
Old Mar 10, 2013 | 03:38 AM
Crepitus's Avatar
Crepitus
Ohh 15" wheels. sounds like you need to get the brake tork with bigger piston area on the stock rotors
Old Mar 10, 2013 | 12:11 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Or just eliminate the stock proportioning valve so the rear is seeing the same pressure as the front.
Old Mar 10, 2013 | 12:28 PM
leesvet's Avatar
leesvet
Is there an adjustable proportioning valve?
locks do work but they are only f/r...one or the other usually. Could one be made to do both? with proportioning?
must be somehting out there..
Old Mar 10, 2013 | 12:59 PM
383vett's Avatar
383vett
C409 reminded me in a PM about Rossler's transbrake for a 4L60e. I'm going to look into this. I have a friend that uses Rossler's transbrake on his Callaway with a 4l80e. The thing is really slow to release and he is having a heck of a time with reaction times. I think it's the nature of the 4l80e.
Old Mar 10, 2013 | 01:00 PM
383vett's Avatar
383vett
Originally Posted by Tom400CFI
Or just eliminate the stock proportioning valve so the rear is seeing theh same pressure as the front.
Tell me more Tom. Willie
Old Mar 10, 2013 | 07:37 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Hey Willie.
Right now, and on most any stock car, the proportioning valve limits pressure to the rear wheel cylinders/calipers. This occurs in a "rising rate" fashion in stock cars so that under light pedal pressure, the rear brakes are doing their "fair share" of the work. As pedal pressure increases however, loads transfer toward the front axle. To prevent rear-wheel lock up, pressure rise rate falls off, as pedal pressure increases. See chart here:
^^This is where you are having the issue; heavy pedal pressure, front wheels skid, rears roll. Not enough rear braking force or friction.
I would never recommend removing the proportioning valve on a street driven vehicle, but since yours is trailered, track-only and massively rear-traction biased, I think it would be O.K. in your case. By removing this valve, you'll have equal pressure rise as you increase pedal pressure, to both the front AND the rear brakes. This is effectively increase your rear brakes' holding power.
Old Mar 10, 2013 | 07:44 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Is not the rear C5 brake the same as the early C4 front?
Old Mar 10, 2013 | 07:53 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
No. Not at all. Rear C5 brake is about the same diameter as early/"base" C4 brakes, but the rear C5 rotor is much thicker, and also has an internal expanding drum/shoe parking brake system. LIKE the "early" C4, but not interchangeable at all.
Caliper is also completely different.
Early front:
C5 Rear:
Old Mar 10, 2013 | 11:46 PM
383vett's Avatar
383vett
Hey Willie.
Thanks Tom, how does one going about removing the valve? I'm out of town away from my fan on my I phone. Thanks again. Willie
Old Mar 11, 2013 | 12:27 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I've never done it, but don't feel that it should be too hard. The valve (as you may already know) is located just below your master cylinder. Removal is straight forward. The front brakes go "straight through" -there is no management of the pressure so simply connecting the MC cylinder front circuit outlet to the lines going to the front brakes with a union would keep the fronts functioning the same.
For the rears, same thing. Seems to me that if you physically remove the PV, re-bend the MC>PV line and rear brake lines to align w/each other and install a female-female union, that would do it -like this...
JEGS
Here, someone has removed their proportioning valve (nothing in the front brakes circuit) and installed an adjustable proportioning valve in the rear circuit....
You could do the same thing, but w/o the adj. prop valve, using a F/F union...
Old Mar 11, 2013 | 01:35 AM
383vett's Avatar
383vett
Interesting. What does the spring mod in the valve do?
Old Mar 11, 2013 | 03:54 AM
tunedport85inject's Avatar
tunedport85inject
Early front:
C5 Rear:
Early 85 c4,since i had a good deal in a C5 kit f/r:Can i keep my rear parking brake system,changing the r rotor?
To C5 brakes
Old Mar 11, 2013 | 10:53 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
It increases pressure to the rear, compared to the stock spring.
Say what? Are you asking if you can run the C5 rear rotor on an early C4? If so, then no. Not w/o a lot of custom machine work and "engineering". Anyway, the C5 rotor is not meaningfully larger in diameter than the stock one...only (meaningfully) thicker.
Old Mar 11, 2013 | 11:50 AM
383vett's Avatar
383vett
I might try that first. Is the replacement spring stronger or weaker than stock. Can the stock spring be shimmed or cut?
Old Mar 11, 2013 | 12:00 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
No since in modifying the stock one, it's only $13 from DRM. Bias Spring
