Timing Question
Old Jun 17, 2002 | 09:57 AM
steveelsbury's Avatar
steveelsbury
Default Timing Question
Hi Guys,
I'm trying to set my base timing, and see that the manual recommends running the engine at 2000 rpm to set the timing. Having disconnected the advance wire from the distributor, I expected to see no advance as revs increase, but when the rpms pass about 1500, I see a 10 degree jump in advance. If I set 6 degrees BTDC at 2000, the car will not idle!
Can anyone tell me what is going on here?
Thanks, Steve
Old Jun 17, 2002 | 12:11 PM
Hendej's Avatar
Hendej
Default Re: Timing Question (steveelsbury)
What manual says that? Not the Helms manual. :confused: Base timing is always done at idle, EST disconnected. Didn't know the computer would add timing at any RPM with EST disconnected. Interesting.
Edit: Just noticed you have MSD ignition. Nevermind! No clue!!
[Modified by Hendej, 10:13 AM 6/17/2002]
Old Jun 17, 2002 | 12:13 PM
scorp508's Avatar
scorp508
Old Jun 17, 2002 | 12:18 PM
steveelsbury
Default Re: (scorp508)
I've disconnected the MSD to keep everything simple. The advice to set timing at 2000 rpm comes from a Haynes Workshop Manual. I'll go and check the proper GM shop manual now ( an inch and a half thick bright red book, and very hard to find anything - hence I usually work from the Haynes manual) - it never occurred to me that Haynes might be wrong!
I've confused where the advance is coming from though. I thought with the EST connector disconnected, there was no way for the timing to be advanced. Retarded, yes, if I get knocks, but not advanced? :crazy:
Old Jun 17, 2002 | 12:21 PM
Bluevette85's Avatar
Bluevette85
I have my idle set to 650RPM in drive and timing 6-8deg.
Old Jun 17, 2002 | 01:50 PM
jmr302's Avatar
jmr302
I'm having similar difficulties, Steve, and I'm running the MSD 6AL. I'm going to try running the car without the MSD box and see what happens.
Old Jun 17, 2002 | 01:53 PM
steveelsbury
Default Re: Timing Question (jmr302)
Well, I checked the official GM manual, and cannot actually find a timing procedure anywhere in it. It says "Set the timing according to the plate on the radiator". Obviously written for people who are assumed to know how to do it.
So, does everyone set timing at idle? It seems so from the replies above.
Interestingly, the manual also mentions setting the base idle to 450 rpm when adjusting the IAC valve. Mine won't keep running that low - I have to get it over 600 before it keeps running.
Old Jun 17, 2002 | 02:16 PM
Bluevette85
GM issued a tech bulletin years ago increasing the recommended idle on the 85 to 550rpm with esc disconnected.
To Timing Question
