Differential Rotation (under car video)
Old Mar 15, 2013 | 03:53 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
Default Differential Rotation (under car video)
Is it normal for the diff to rotate slightly? Is this what the ZFdoc c-beam plates eliminate, or did I bust yet another c-beam bolt?
I'll be crawling under the car this weekend to check regardless, but wanted to see what y'all thought.
Old Mar 15, 2013 | 04:12 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
You probably already know this:
Old Mar 15, 2013 | 04:13 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Cool view! Looks ok to me, thats why everything is mounted with bushings to allow for some movement. I would run a bit more pressure in the tires though.
Old Mar 15, 2013 | 04:25 PM
shakedown067
Thanks. Hell I'm running 34psi now. Not even rolling over all the way to the side groove yet (technical term is escaping me at the moment). Actually a good distance from it.
Certainly didn't over tighten them, at least I didn't. Only changed the rear bolts a few months ago.
Old Mar 15, 2013 | 05:54 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I don't agree. The C-beam is not mounted to the diff w/bushings (as you know) nor is it to the trans. There should be very very little movement in that direction. I think something is broken or bent. The Diff in my CTS-V moves that much...but that's b/c it's mounted in three mushy rubber blobs...all in close proximity to the centerline of the diff. The C4 has a lever-arm that is ~8' long. There should be very little movement, IMO.
CTS-V, camera mounted sideways...
Old Mar 15, 2013 | 06:36 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
These are great videos, but the FSM calls for 59 ft-lbs at the differential, and 37 ft-lbs at the transmission.
Old Mar 15, 2013 | 07:10 PM
kimmer's Avatar
kimmer
Talking about the mounting bushings on the bat wing and suspension. If parts don't give they break. Think about it, diff & drive line connected to trans & bolted to the engine which moves quite a bit under hard throttle.
Old Mar 15, 2013 | 07:31 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Way cool video
Could be the engine mounts or the diffmount at the end of the batwing.
Old Mar 15, 2013 | 07:34 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I have thought about it. The engine does move (rotates, mostly) with stock motor mounts... but for it to accommodate the movement in THAT vid, it would have to be rising from it's mounts a good 6"! I hope the OP's engine isn't moving that much. I think the C beam is deflecting or there is a loose or broken bolt. Another vid is in order...this one of the C-beam!
Old Mar 15, 2013 | 08:12 PM
leesvet's Avatar
leesvet
I gotta agree with Mr Tom...
the C-beam is solid mount at both ends to prevent movement in that way.. the batwing ears are 90 degrees to that so they would have to be gone to allow that movement.
So...the batwing and trans should move together...if at all but it has to be very limited..only what the diff mount ears would allow and that ain;t much.
I'd start by looking hard at the trans bolts in the beam...rear end bolts too.. I'd even take a close look at the lattice of the batwing! thats tweaking way too much for aluminum to be happy...thats a loose or broken mount or possibly broken batwing the way it twist with the torque.
somethins not right !
Old Mar 15, 2013 | 08:39 PM
Glenno's Avatar
Glenno
Following
Old Mar 15, 2013 | 08:42 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Originally Posted by BrianCunningham
Way cool video
If those bushings are rotten it will move. Those bushings are a PITA to replace.
Old Mar 15, 2013 | 11:15 PM
project C4's Avatar
project C4
Sure doesnt look right to me. Hard for me to believe the c beam can deflect that much without something being loose or broken.
for it to move like that I would think it would be at diff end of the c beam.
Very neat video
Old Mar 16, 2013 | 03:59 PM
shakedown067
Diff doesn't deflect left or right, so talking to Paul at Van Steel, we've ruled out bushings! Will let you know when I check out the c-beam bolts.
Old Mar 16, 2013 | 04:20 PM
lkl2005's Avatar
lkl2005
Jesus H Christ, You have serious HP there sir.
Old Mar 16, 2013 | 04:26 PM
shakedown067
All stock LT-1
Old Mar 16, 2013 | 04:54 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by shakedown067
All stock LT-1
That may very well be what's missing! STOCK PARTS ! It would be interesting to put at least the stock lower control arms back in the car and do the same "visual". Beam plates are conversational, but with one video in "the can" I believe I'd go about replacing everything that has "heim joints" with conventional bushing stock parts and try it. There's nothing to be lost and it could be very educational. If the "heim joints" create this issue there's no doubt that there's wear being created at the rear and front beam mounts and the "beam plates" would certainly aid in the constant re-torquing that's going to be required. This might be a very good reason to consider the beam plates. It would seem that what's been documented here would indicate there's constant wear on both the transmission and differential mounting bolt bores.
Do you have all of the OE parts still?
To Differential Rotation (under car video)
Old Mar 16, 2013 | 06:44 PM
383vett's Avatar
383vett
Nice video. I see the differential moving up or down about an inch or so. The batwing bushing could easily deflect 1/2" each way. Looks normal.
Old Mar 16, 2013 | 07:03 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I don't see how the batwing bushings could deflect in that direction, that much. Look at the angle of deflection...not just the amount in inches...
How could heim joints for the suspension possibly have an effect on this issue??
The issue is the rearward rotation of the diff, under acceleration. The suspension (no matter how it's secured) has no impact on those forces. It's ALL about the C-beam. That is 1 of the 2, C-beam's jobs, is to prevent the rearward or forward rotation of the diff, under acceleration and deceleration, respectively. LONG before slapping stock, mushy bushings back into the suspension, as a test, I'd inspect the item who's job is to prevent that motion. I'd inspect the C-beam.
Old Mar 16, 2013 | 07:09 PM
383vett's Avatar
383vett
The c-beam is a really flimsy piece and deflects quite a bit under load.
