fan control relay
Old Mar 16, 2013 | 03:56 PM
hitmanpty's Avatar
hitmanpty
Default fan control relay
hi
my radiator fan work all the time. i just have to turn the key to on possition and the fan start spining.
so i decided to check the wire. diagram
I find out that the previus owner had been plaing with the fan control relay
all the wires are conected ok. but on terminal E red wire to battery. there is an extra Orange cable attached to this cable.
It go fron the red cable to the big wire bundle under the brake buster drum.
Any body knows what is this orange cable???????.
Here are to pictures for referance. on the photos the wire look diferent color but belive me is Orange
[IMG][/IMG]
[IMG][/IMG]
Old Mar 16, 2013 | 08:54 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Take that wire off. Then install a toggle switch under your dash somewhere convenient and run that wire to the switch. This will allow you to turn it on and off at your convenience.
See if you can get some liquid electrical tape (available at a boating store) and then put that and a shrink tube over the splice.
Old Mar 16, 2013 | 09:54 PM
leesvet's Avatar
leesvet
IIRC....
red wires are HOT with key on/run
orange wires are HOT all the time.
or vice versa...
Old Mar 16, 2013 | 10:41 PM
vetteoz's Avatar
vetteoz
Your wiring is non stock so all bets are off.
The orange wire could be one of the several under hood power feeds;
fuel pump / pump OP switch / MAF relays / etc
Old Mar 17, 2013 | 12:04 AM
hitmanpty's Avatar
hitmanpty
i will check tomorrow i report back allí ready late here
Old Mar 17, 2013 | 08:07 AM
leesvet's Avatar
leesvet
If it is factory wiring, it will either be fused or come from fusable links under the battery box.
this appears to be a bypass around the relay.
does that orange wire go to the blk/red wire in the relay?
why people do it that way...I dunno. Soooooooo much easier, safer to simply ground the green grnd wire and go home.
Old Mar 19, 2013 | 04:28 PM
hitmanpty's Avatar
hitmanpty
OK i TEST THE CABLE. at this time when I turn key to on. (no start.) the fan stay off.
that is with the orange wire umplug.
now if I plug the orange wire to the battery or to the red wire on the relay. the fan turn on inmediately.
I will have to trace that orage cable and see where it go. also I have to try to run the engine into hot to see if the fan start when reach hi temperature
Old Mar 25, 2013 | 10:45 AM
hitmanpty's Avatar
hitmanpty
ok need help with the orange wire. I disconnect the orange wire try to start the car I get no start condition. I conect the orange wire directly to battery. I get start and the radiator fan start spining.
try to trace this wire back and it get lost in the loop behin the motor.
what is this orange wire???? can any body tell me
Old Mar 25, 2013 | 12:20 PM
Deepa's Avatar
Deepa
in your situation with that car, reconnect it and let the fans run all of time.
Old Mar 25, 2013 | 05:47 PM
hitmanpty's Avatar
hitmanpty
that what i did. for the moment. but that will not anwer my question.
Old Mar 26, 2013 | 12:44 AM
vetteoz's Avatar
vetteoz
A orange power supply wire goes to items that are essential for the engine to run that I listed in post #4 above
Maybe time to invest in a FSM that has all the stock factory wiring diagrams so you can put trace and things right ?
Old Mar 26, 2013 | 10:52 AM
hitmanpty's Avatar
hitmanpty
ok i connect the orange wire to battery .away from the fan relay . i check the wire diagram and on the fan relay and all look to be connected ok. bit i keep getting fan spining all the time .
To fan control relay
