where to next
Old Mar 18, 2013 | 11:18 AM
dhewett's Avatar
dhewett
3rd Gear
Default where to next
1996 vette LT1 have replaced the water pump, the opti-spark, the crankshaft position, and the engine control module. The check engine soon light was on and continues to be ON. All work was done by chevy technicians. Car cranks, runs great and have driven over a thousand miles since work was done, no issues. Any suggestions as to what to do next?
Old Mar 18, 2013 | 11:42 AM
don hall's Avatar
don hall
A Chevy dealer did all the repairs, and let the vette go with the trouble light 'on'? Doesn't sound right. A dealer would not miss an opportunity to add to his revenue by letting a vette loose with a trouble light glowing.
93 ragtop's Avatar
93 ragtop
has anyone scanned to see what codes have set? If so, what were they?
Old Mar 18, 2013 | 12:01 PM
383vett's Avatar
383vett
Bring it back and tell them you picked the car up with the light on.
Old Mar 18, 2013 | 12:39 PM
Axial's Avatar
Axial
Not a whole lot to go on without a code. As a 1996, I would hazard a guess that it's an O2 sensor somewhere. You have four of them, assuming the car is stock. Since the car is apparently driving fine, it would be one of the two post-cat sensors.
To where to next
