Well I was able to finally get some data logging in today just toying around with it to get it to work and was looking at the graph for my map sensor
At 100%TPS it shows 29 inches of vacuum and at cruise it is showing roughly 12 inches. Anyone know if this is normal or needs fixed?
If it helps i can post the log or send it via email
Thanks!
MAP = manifold air pressure, at WOT the manifold air pressure will be near 100 KPA or 29.92 PSI. At cruise it will be less. The MAP sensor is working fine.
