Burnout question
Old Mar 19, 2013 | 12:49 PM
bmeek9607's Avatar
bmeek9607
Default Burnout question
This may be a bit of a stupid question but how do I do a burnout in my 85 corvette? Is there a way to turn off the limited slip differential. I can't find a button anywhere and it does not say anything in the manual. All I seem to be able to get is some tire squeak. I can lay a 20 foot strip of rubber in my crown vic but can't in my corvette........
Old Mar 19, 2013 | 01:38 PM
nickgost's Avatar
nickgost
First of all auto or standard.
You can never turn off a LSD, it is a dif with friction plates in it so that one wheel cant spin hard with the other doing nothing.
Old Mar 19, 2013 | 01:45 PM
cv67's Avatar
cv67
St. Jude Donor '05
Straight axle cars are easier to do them in
Vette was designed to stay planted
What you need is some real power behind you..
Or put your foot to the floor in N and drop it in D.
Post pics of parts in a bucket LOL
Personally I dont get the fascination with burnouts. its just super hard on parts.
ya want the car to hook and go...let the other guy spin and leave him sitting there.
Old Mar 19, 2013 | 01:49 PM
bmeek9607's Avatar
bmeek9607
its a manual
Old Mar 19, 2013 | 01:50 PM
bmeek9607's Avatar
bmeek9607
I dont do burnouts alottttttttttttt.. But it just makes me mad that my old man car can spin more than the vette
Old Mar 19, 2013 | 02:18 PM
Bob1985z51's Avatar
Bob1985z51
Ok put the clutch in, rev up the motor to about 3500 rpm and dump the clutch. That's basic later you can start power braking but for now I think you should just stick to basic.
I burnout quite a bit and its just fun... Except for when I need tires
Have fun!
Old Mar 19, 2013 | 02:19 PM
bmeek9607's Avatar
bmeek9607
Have fun!
Ever had any problems with your vehicle from burning out? Other than replacing tires
Old Mar 19, 2013 | 02:22 PM
Bob1985z51's Avatar
Bob1985z51
Not in my case, it's hard on parts but not as hard has launches with slicks.
Losing traction isn't as hard on parts, it's when you gain traction and the drivetrain gets put under more stress.
Old Mar 19, 2013 | 02:40 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
Man, and I wish mine wouldn't do a burnout! And that's with the Anemic 2.59 rear end, don't know what the hell I'm going to do with a 3.45.
Old Mar 19, 2013 | 03:04 PM
lkl2005's Avatar
lkl2005
Like most of these guys in here I want my rear tires to grab a hold of the asphalt when we hit that right pedal. Thats the fun of it. I get my kicks when I hit that little patch of gravel making a turn and it slides out a little on acceleration. I am in my 50's, This car is an all original 86 with only 19K with good tires. I would be an idiot to dump the clutch at 3000 on dry pavement. I might as well cheat on my wife because the girl would be in pieces on the pavement.
Old Mar 19, 2013 | 03:48 PM
Slow_Lane's Avatar
Slow_Lane
You might be suprised. I had a fox body mustang with 2.73 gears back in the day. It was nearly impossible to launch..too little throttle, engine bogged, much more would overcome the resistance and spin the tires mercilessly. Sweet spot was in there but hard to find. Switched rear to 3.73 and launches were much easier. Sure, I could still easily spin the tires at will but with the new gears the engine rpm at launch was better aligned with the power band and it was just all around easier to launch and drive.
Old Mar 19, 2013 | 04:14 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Old Mar 20, 2013 | 12:17 AM
higgyburners's Avatar
higgyburners
I believe in the Beer Fairy
St. Jude Donor '15,'19
I remember when i was in my teens my older sister bought a 85 Corvette so took it for a test spin and had no problem roasting the tires in her Automatic untill she found out...
Old Mar 20, 2013 | 12:44 AM
84VetteMan205hp's Avatar
84VetteMan205hp
i just did a burn out earlier after my job interview in my 84 and it was pretty easy. brake + gas = tire spin
Old Mar 20, 2013 | 01:03 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Old Mar 20, 2013 | 02:07 PM
shakedown067
Yeah, I'll just have to watch the launches, but I want to switch for better throttle modulation in 2nd gear for autocrossing. 2nd gear blows with the 2:59.
Old Mar 20, 2013 | 02:19 PM
383vett's Avatar
383vett
Like this...
To Burnout question
Old Mar 20, 2013 | 02:56 PM
JrRifleCoach
Or this
Old Mar 20, 2013 | 03:56 PM
93 ragtop's Avatar
93 ragtop
or this!!
Old Mar 20, 2013 | 04:45 PM
mxnuke's Avatar
mxnuke
Line-lock is your friend...
