Y-pipes
Old Mar 23, 2013 | 01:38 PM
90TorqueMonster's Avatar
90TorqueMonster
Default Y-pipes
So I'm looking to change my stock (after the headder) y pipe. Its old. I see hooker makes a y pipe for c4s is there a difference in size?should I go larger?
Old Mar 23, 2013 | 01:58 PM
LoneStarV's Avatar
LoneStarV
Do you have precats in your set up now? If not and you have hooker headers their y pipe will work fine. No need to go larger unless you have gone big on engine mods pushing a bunch more air than stock. TPIS sells a y pipe as well....one is a bolt in right to the large main cat. The other has a straight end no flange.
Old Mar 23, 2013 | 02:04 PM
90TorqueMonster
Thanks for the info!
I have one cat which im going to delete, whats the stock size for the y-pipe?
Old Mar 23, 2013 | 02:18 PM
LoneStarV's Avatar
LoneStarV
I assume you mean the main cat? If your 90 is like my 88 be aware it has a line back to the air pump that will have to be removed as well. Then you'll need one of these to replace it unless you plan on a custom exhaust system.
http://www.ebay.com/itm/CHEVROLET-CO...-/120704668959
Old Mar 23, 2013 | 03:04 PM
90TorqueMonster
Yea my cat has the line too; I plugged it up. I'm not so worried about deleting the cat, I'm just wondering what my stock y pipe size is and if I get a hooker y pipe that might (be larger) if it'll improve anything, if not where can I get a new old stock pipe?
Old Mar 23, 2013 | 03:40 PM
LoneStarV's Avatar
LoneStarV
Is your engine stock? Close to stock? Do you have shorty headers, long tube headers or stock exhaust? If LTH headers then you or a PO modified the stock exhaust to connect to long tube headers. If you have shorty headers or stock exhaust manifolds don't waste your money on a new stock y pipe especially if the cats have already been cut out or gutted.
Old Mar 23, 2013 | 05:22 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
The stock y-pipe is 2.25". Aftermarket Y-pipes HAVE been available in a larger 2.5" diameter. I thought it was worth it.
Before I built my 383, I had 2.5" front to back (except the stock manifolds) on a 350. I had glass packs, main magnaflow cat, and dual slash cut 3" tips. The sound was perfect and performance SEEMED better than stock...not much but a bit.
If you're looking for a bump in performance, there are more economical ways...but if sound/looks are part of the goal, I recommend it.
This is where I purchased mine...several years ago.
http://www.allencorvetteexhaustsystems.com/
Old Mar 23, 2013 | 09:33 PM
90TorqueMonster
Thanks GregPenn, you've always helped me on a thread! I don't really know if I should spend 200 bucks for a larger y pipe, or get one made or buy one like I have on now. And I have long tube headders
Old Mar 23, 2013 | 09:46 PM
90TorqueMonster
So I decided I'm going to go with the 2 1/4 pipe. Where can I get one?
Old Mar 23, 2013 | 10:30 PM
l98tpi's Avatar
l98tpi
Max G’s
TPIS or Mid America for sure. Corvette Central and Ecklers may have them as well. Just check them all out and price check. Thank God for the Net.
Old Mar 24, 2013 | 12:53 AM
GREGGPENN's Avatar
GREGGPENN
It's pretty rare for someone with longtubes to stick with the stock 2 1/4" piping. If you're going to buy new pipe anyway, the large 2.5" size won't hurt you, should help you, and will allow more room for modification.
Old Mar 24, 2013 | 08:06 AM
90TorqueMonster
Ok, I just figured only because I don't really have that many mods
Old Mar 25, 2013 | 05:54 PM
j-wireman's Avatar
j-wireman
If you have headers, you might as well go with a true dual exhaust. Better flow than with a y-pipe setup.
To Y-pipes
