my winter project
Old Mar 24, 2013 | 04:17 PM
yorkfitter's Avatar
yorkfitter
Default my winter project
Got this for myself for Christmas, and a TKO from kiesler for my 86. Got a lot of work ahead of me. It's a 383 roller engine with forged crank, pistons + 30, dart 200 heads, zz409 cam, mini ram, 7 quart oil pan, clevite bearings, and 28# injectors. Built by TPIS.
Old Mar 24, 2013 | 05:58 PM
pmihaltian's Avatar
pmihaltian
Slingshot
VERY
Old Mar 24, 2013 | 06:17 PM
STL94LT1's Avatar
STL94LT1
Very nice!!!
More details on the engine.
Ah, just noticed you are in Wentzville. I work at the GM plant.
Old Mar 24, 2013 | 07:12 PM
yorkfitter's Avatar
yorkfitter
I work for Johnson controls and I have worked at the GM plant in the power house on the chillers that cool the plant.
Old Mar 24, 2013 | 07:37 PM
WW7's Avatar
WW7
Sweet motor......I have Dart heads on my 89 also, If you look at the head on the passanger side you will see that it only has 3 holes drilled for accesories.. If your a/c bracket is like the one on my 89, you will have to drill and tap another hole in the upper right corner for the a/c bracket to bolt up properly...I didn't know this before my 383 was already in the car, just thought I would save you a headache by letting you know to drill and tap it before putting the motor in..It's much easier to do this on a stand .......Good Luck with the new motor..WW
Old Mar 24, 2013 | 11:26 PM
Ziggy91's Avatar
Ziggy91
I'm jelly.
Old Mar 24, 2013 | 11:43 PM
cv67's Avatar
cv67
St. Jude Donor '05
Thats going to be all kind of fun on the street. nice numbers for what it has in it.
Old Mar 25, 2013 | 08:46 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
To my winter project
