steering rack inner tie rods
Old Mar 25, 2013 | 06:02 PM
Elrick's Avatar
Elrick
Default steering rack inner tie rods
I removed my steering rack as I thought I needed new inner tie rods. How can you tell for sure when you have the rack off? The rods dont flop around and they have good resistance and do not seem loose. The outer tie rods are very loose as compared to the new moog ones I bought. Just wondering if this is my problem. When it was all together and I placed my hands at 3 and 9 oclock I had a lot of movement but I could not see it coming from the outers. I had no leaks at all from the steering rack either. I was going to have Turn one rebuild it but their turn around time is 8 to 10 weeks and I am not sure I need a rebuild. They only charge $200 so it seemed worth it but now I am thinking it wasnt the inner tie rods. The car has around 100k on it. I am just hurting a bit for money now. Just need to know how to test the inner tie rods when the rack is off the car. Thanks
Old Mar 25, 2013 | 07:44 PM
leesvet's Avatar
leesvet
why go after the rack?
did you rule out wheel hub bearings? AND ball joints?
Old Mar 25, 2013 | 08:55 PM
Elrick's Avatar
Elrick
I replaced the hub bearings and the ball joints felt solid. My understanding with the ball joints was to check them by holding the tire on top and at the bottom, 12 and 6 to see if there is movement. When I did this everything was solid. I got underneath to try and see where the movement was and it did not look like it was at the outer tie rods or the ball joints and my mechanic had aligned it after I did all 4 hubs and all the rear bushings, and he said he thought the steering rack might be loose at the inner tie rods. since I did everything else and the car has 100k on it I thought I might be able to change out the rack fairly easily. Now I am thinking that even though I couldnt see it, it may have been the out tie rods. when I got the rack off I can move the out tie rods around and they are just loose and sloppy as hell. I guess I just dont want to pay for a new rack if its not needed, however, it will suck to put the old one back on and find I still have the problem.
Old Mar 25, 2013 | 10:47 PM
leesvet's Avatar
leesvet
Outside toe rod ends are not bad...approx $30 ea if IIRC... go with that for now, as I am positive it will be an improvement. Reinstall the rack. It WILL be tighter. Inners are wet and protected from dirt & grit so they do not wear like the outer.inner has limited movement as well..less wear.
I am amazed at how long these will go ONLY IF they are bathed in grease. They need to be greased every oil change. Mine has 300,000 miles on the chassis and a FEW of the bushings are starting to get hard and brittle. None of the grease-able joints are shot, and I've only HAD to replace bearings a couple times.
Grease is cheap.
Old Mar 26, 2013 | 12:57 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
If the inners are resistive to movement, rule them out.
The outers need replacing. There should be some resistance.
Can you describe the condition of the rack mount rubbers?
Is there any slack in the steering column coupler "rag" joint?
Clamp or tie down the end of the steering shaft and try to move the steering wheel.
Old Mar 26, 2013 | 11:37 AM
Elrick's Avatar
Elrick
the rack bushings seem fine, they are not chewed up or worn out and squished like some of the suspension bushing that I have replaced. I have not tried to check the steering column but now I will, thanks.
To steering rack inner tie rods
