Hood stuck not your same old issues
Old Mar 27, 2013 | 08:42 PM
ninjaneer911's Avatar
ninjaneer911
Default Hood stuck not your same old issues
I have an 86 vert that was wrecked. I replaced the hood and front bumper. In an attempt to get everything lined up, I loosened the hood hinge mount bolts AND the HINGE PIN BRACKET bolts.
My cables were almost too loose before the accident. Someone shut the hood all the way. The latches will not release. I tried: (all while shaking pounding and pulling up on the hood) the release lever until it cracked. I used two pair of pliers on the cables individually, one to hold the jacket the other to pull the cable. I made the hood release rod tool. Finally I removed the fender well got my hand onto the release lever.. and it will not move. So I fished a piece of wire around the lever out through the cowl by the wipers. I pulled the wire until it almost broke. ALL WHILE "EXERCISING" THE HOOD.
WHERE DO I GO NOW FOLKS??? Piano wire to cut through the springs and pin? Saw the hood in half?
Im almost broken...
Old Mar 27, 2013 | 09:37 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Can you onbolt the plate the pin is bolted to from the hood? There are 3 bolts holding the plate on.
Good luck
Old Mar 27, 2013 | 11:21 PM
leesvet's Avatar
leesvet
if you use the "tool" as intended, it WILL move the lever in the latch box and let the spring pins free. Its not fun, its not easy. It can take hours. It takes patience and practice. The other option is a hole saw and $3500 for a new hood. Used ones are lots cheaper but never in your color...
BTW
this is why we make emergency cables....
Old Mar 28, 2013 | 12:26 AM
Jerry Roubos's Avatar
Jerry Roubos
I need a set of the emergency cables. I ordered a set from two different venders six months ago and both say they are still on back order. let me know if any one knows a vender that has them in stock. I did rig up some temporary ones just in case.
Old Mar 28, 2013 | 10:21 AM
ninjaneer911
Again, I can place my hand on the release lever. I have a wire wrapped around the lever and can pull on it from outside the hood toward the center of the car (exactly like an emergency release cable). I even placed the tip of the "tool" on the lever and pulled the lever while turning the tool.
What i believe is that because the pin and plate are so loose, they have shifted over so far that the lever CANNOT disengage. I plan on trying to work it back over to the outside of the car.
The working area is so tight that i do not think you can get a wrench onto the pin plate bolts.
Please keep the ideas coming. I do not want to cut this hood off!!
Old Mar 28, 2013 | 11:38 AM
leesvet's Avatar
leesvet
You can build these from 1/32" plastic coated wire rope(cable) and crimp on ferrels. I ran both to the driver side thru small holes drilled in the rubber liner/seal. Made a loop at the end, hide them so they do not interfere with the wipers and I'm set. I use them to pop the hood often rather than opening the door to reach in and mess with the lever.
Maybe $20 spent on the cables...
Old Mar 28, 2013 | 11:48 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
It's been a while since I looked at one, but can you get a ratcheting box end or something like that, on the pin bolts on the hood, get them off, and get the hood open and then figure out what is up w/the latch/pin assy's?
Old Apr 11, 2013 | 08:39 AM
ninjaneer911
Default Solved!
Guys i lucked out.
I took off the tire, removed the upper fender well attached to the hood and wall able to pull it out. Then removed the rear portion of the lower fender well in front of the battery and was able to access the latch assembly from below. With ample room, i loosened the ENTIRE pin using an open end 1.5 inch wrench (the flat short kind that look like bicycle wrenches). The hood popped open and so did a TASTY ADULT BEVERAGE.
THANKS FOR THE ADVICE PEOPLE
Old Apr 11, 2013 | 09:46 AM
leesvet's Avatar
leesvet
Great !
I was wondering how you;d resolve this....I've seen plenty of stuck latches but never becaise the pin assy was so loose that it absorbed all the slack and could not release.
To Hood stuck not your same old issues
