Would this 2" cogged belt drive system fit within the confines of a C4 engine bay? I will probably have to get a Toledo Pro 2 3/4" cowl high rise hood anyways due to hood clearance issue going to a carb.
383 with a carb, will this pulley system fit? Also, AC will be added, adding another pulley.
Id be worried about it hitting the crossmember maybe someone has one on theirs?
Chris Jones racing makes some super trick low drag pulley setups that are meant for rpm meaning the pumps alts etc.
Its not cheap but they work look killer and will take the abuse. Lots of "performance race look" pumps out there that come
from overseas and split at the seams when you hit them hard.
