Aero mods?
Old Mar 28, 2013 | 11:34 AM
aboatguy's Avatar
aboatguy
Default Aero mods?
Are there any proven aerodynamic improvements available?
Not looking for mirror removal and racer-taping seams..
Things like:
Chin spoilers
Splitters
Belly Pans
Diffusers
If so who makes them and what are the improvements?
Mike
Old Mar 28, 2013 | 07:24 PM
weaselbeak's Avatar
weaselbeak
As far as I know chevrolet really did their homework getting the c4 to be slippery in stock configuration. To be honest i would think you would have to be really moving to get any benefit from any sort of chin spoiler or splitter.
Old Mar 28, 2013 | 07:48 PM
aboatguy's Avatar
aboatguy
Yes, you have to be really moving, and some drag reduction via aero improvements will move how high, really moving is.
Back to the topic
Things like:
Chin spoilers
Splitters
Belly Pans
Diffusers
Old Mar 28, 2013 | 08:44 PM
Crepitus's Avatar
Crepitus
looks to me like the first step is to vent air and pressure out from under the hood. There is an interesting thread on ax/rr that I hijacked (just a little) to discuss C4s. Somebody reported measuring a 2 psi pressure diff above and below the hood. A pair of vents over the 2 & 3 exh primary looks like a good spot to vent pressure as well as heat. There is a good Cad aero map of a C4 on that thread as well.
http://forums.corvetteforum.com/auto...downforce.html
Old Mar 28, 2013 | 09:13 PM
dogfish246's Avatar
dogfish246
This thread has a lot of good info about aerodynamics (specifically for a diffuser build)
http://forums.corvetteforum.com/c4-g...-diffuser.html
Old Mar 28, 2013 | 11:18 PM
mxnuke's Avatar
mxnuke
Been reading tons of threads about the rear diffuser on c4s.But i dont see any place that sells the aluminum ones.A few on here have built them and they look killer.My hold-up would be welding the aluminum,plenty of build info on here though..good luck
Old Mar 28, 2013 | 11:24 PM
cv67's Avatar
cv67
St. Jude Donor '05
Unless you dont mind rivets
Old Mar 28, 2013 | 11:32 PM
dogfish246's Avatar
dogfish246
Why not make one out of fiberglass? You make the piece out of cardboard, saturate the cardboard in epoxy, add a layer or two of fiberglass and then you have your diffuser...
That is my plan lol
Old Mar 29, 2013 | 04:57 AM
aboatguy's Avatar
aboatguy
Thanks dogfish. I read that thread the first time it came around and would have posted to it, but the new thread age rule probably would have resulted in a lock.
Old Mar 29, 2013 | 05:16 AM
aboatguy's Avatar
aboatguy
That was an interesting thread, but how accurate are those CAD aero-maps.
I wonder if the Shinoda Mears kits worked. I remember the threads on IRT Shinoda Mears were mostly on how no one could find one.
http://forums.corvetteforum.com/c4-t...in-please.html
IMO They look great and if they work as well as they looked they be the ticket.
Especially with a working diffuser/partial belly pan
Old Mar 31, 2013 | 12:17 AM
Ziggy91's Avatar
Ziggy91
I can tell you that from years of seeing people put all kinds of "aero" parts on their cars.... 90% don't do anyhthing but make it look better... but some do the opposite.
If you want aero parts that actually work, talk to guys that take their vettes to the track because those parts will usually work in some way. The only real functional chin spoiler I've seen was one on a ZR1 that had brake cooling ducts.
Old Mar 31, 2013 | 10:14 AM
aboatguy's Avatar
aboatguy
Thanks Ziggy, your experience confirms mine (90+% of things that are supposed to enhance performance don't)
However, it seems like the track guys priorities are on things other than drag reduction.
Old Mar 31, 2013 | 10:26 AM
cv67's Avatar
cv67
St. Jude Donor '05
You have to be going seriously fast to even have them take effect if any.
The spoiler GM put on there does a decent job at keeping air from going under the car...hood etc. Like the cowl induction. It works but to really see a gain Id bet youd need to be doing 100 or better.
Old Mar 31, 2013 | 10:30 AM
aboatguy's Avatar
aboatguy
I got it! I understand you have to be moving fast.. I'm looking for high speed improvements.
Mike
Old Mar 31, 2013 | 10:32 AM
cv67's Avatar
cv67
St. Jude Donor '05
Wonder if there is some type of sim program one could play with that mimics those conditions.
Old Mar 31, 2013 | 10:56 AM
dogfish246's Avatar
dogfish246
Here is a nice graph for exactly that info (assuming it is correct):
Old Mar 31, 2013 | 12:11 PM
aboatguy's Avatar
aboatguy
That's from this Corvette Fever article
http://www.corvettefever.com/techart...unnel_testing/
To Aero mods?
Old Mar 31, 2013 | 12:15 PM
bob guzzy's Avatar
bob guzzy
Well if anyone wants a greenwood spoiler when I get my car here from florida ask and you just might have one, in my mind a corvette is just fine the way it rolls off the assembly line.
Old Mar 31, 2013 | 01:18 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
The Shinoda kit is THEE ONLY body kit that made the C4 sexy!
Old Mar 31, 2013 | 04:17 PM
aboatguy's Avatar
aboatguy
but does it make it faster?
