Fuel pump
Old Mar 30, 2013 | 11:39 PM
Captaintim's Avatar
Captaintim
Default Fuel pump
Question
New to me a 1993 after a 60 or so run came home and noticed fuel pump humming what's next?
Old Mar 31, 2013 | 12:14 PM
leesvet's Avatar
leesvet
fuel relay is probably stuck ON. Replace the relay.
Old Mar 31, 2013 | 05:18 PM
Captaintim's Avatar
Captaintim
It's noticeable when it has been running for a while didn't,t know to be concerned or not new car to me getting acquainted with it. Its my only concern at this time
Old Mar 31, 2013 | 06:37 PM
vetteoz's Avatar
vetteoz
With the engine running or not ?????
More likely to be a faulty oil pressure switch that supplies power direct from the battery to the pump
( even when key is off )
Old Mar 31, 2013 | 08:56 PM
Captaintim's Avatar
Captaintim
No not running when it's off.
After the car has been driven and at operating temp. At idle (I notice) the pump humming you could even feel the pump running through the fuel cap. No running problems just an elevated pump hum at idle. Thanks
Old Apr 1, 2013 | 07:13 PM
93Rubie's Avatar
93Rubie
Shoot that is normal. I car hear mine over my exhuast if I listen for it at idle. They are LOUD *** pumps. So are all GM fuel pumps from that vintage.
Old Apr 1, 2013 | 09:38 PM
Captaintim's Avatar
Captaintim
Good deal thanks for the info. Guess a little over sensitive worrying over something I'm not totally familiar with.
Old Apr 1, 2013 | 11:41 PM
leesvet's Avatar
leesvet
Great Point !
Yep. Thats a "hot always" circuit....and a direct path for power to the pump... I would not have ever thought of that.
Those OP switches get forgotten about as soon as everybody knows what they are and what they do. I did.
Old Apr 7, 2013 | 10:26 PM
mixalive's Avatar
mixalive
Hey guys. Can you tell me where is the Oil Pressure switch mounted on a 92 LT1?
Old Apr 7, 2013 | 10:43 PM
l98tpi's Avatar
l98tpi
Max G’s
The fuel pump has a vibration dampener on it. They reduce vibration, which in turn makes the humming noise you hear. I replaced my fuel pump a couple years ago and have to really listen to hear it come on when turn the ignition switch to on. Your dampener is probably missing. It is not necessary, but will help prolong the life of the fuel pump. And if you need to replace your fuel pump it's not a hard task.
Old Apr 8, 2013 | 12:14 AM
vetteoz's Avatar
vetteoz
The 3 wire unit located at rear of block
(disregard red circle , believe that is the 1 wire unit )
Old Apr 9, 2013 | 11:11 AM
mixalive's Avatar
mixalive
Thanks..
To Fuel pump
