The answer is yes, a 95 will bolt right in change the timing chain cover and use all of your EBD2 sensors and the car will run fine.
and the reluctor wheel and the associated stepped style crankshaft key from the 96; should probably use the 96 crank hub; it may be slightly shorter to accommodate the thickness of the reluctor wheel
Thanks I was coming back on here to add that...
(I was in a rush bunch of family over for Easter Dinner)
the 96-97 LT1 hubs are a couple of RCH shorter IOT make up for the reluctor
