Muffler Clamp Bolt Torque Spec ????
Apr 3, 2013 | 04:53 PM
Does anyone have an exact torque spec for basic steel muffler clamps ?
Seems every time i try to tighten the bolts either they are too loose and get exhaust leaks or i over tighten them and bend the pipes.
Thanks!
Apr 3, 2013 | 05:53 PM
According to Google ...... 40 to 80 ft. lbs. -- varies per manufacturer of clamp (not much help).
My experience has been to torque until you see the pipe indent, then
grab a beer.
Apr 3, 2013 | 08:36 PM
I believe there has never been a muffler clamp that has been torqued in the past 20 years. They are not supposed to be torqued; just tightened.
Apr 4, 2013 | 01:40 PM
Quote:
Originally Posted by
383vett
What about the muffler bearings? I hear they can squeak if over tightened.
Apr 4, 2013 | 01:41 PM
C4 of the Year Finalist
Apr 4, 2013 | 01:56 PM
Thanks everyone i googled it also but the torque specs were all over the place i figured someone on here would have had a more accurate idea !
I'll start again at 20 and work my way up
Thanks !
Apr 4, 2013 | 02:20 PM
Dude , April fools was a few days ago...Your to late..
..WW
Apr 4, 2013 | 02:53 PM
..WW
Not an aprils fools day question i was serious !
It seems rebuilding an engine is easier than something as simple as not over tightening a muffler clamp bolt !
Apr 4, 2013 | 03:19 PM
GQ-ROD
Then weld them instead of using a clamp...WW
Apr 4, 2013 | 06:02 PM
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
GQ-ROD
Maybe the guy at the local muffler shop can help.
I'm wondering what he sets his air impact at?
Apr 4, 2013 | 06:21 PM
JrRifleCoach
2 clicks from the left.
