cat removal
Old Apr 4, 2013 | 08:24 PM
chillin-n-killen's Avatar
chillin-n-killen
Default cat removal
i am having problems with my catalytic converters they rattle all the time...if i have them removed and straight pipe welded in its place will that cause any codes to pop up. i understand the o2 sensers are near the exhaust and i should be fine....also heard it would improve performance is that true ??dont want to screw something up. any help will be appreaciated...jerry tnx and god bless.
Old Apr 4, 2013 | 08:42 PM
LoneStarV's Avatar
LoneStarV
Just hollow them out then no need to weld anything.
Old Apr 4, 2013 | 08:43 PM
cv67's Avatar
cv67
St. Jude Donor '05
Wont go any faster than if you had good cats up to you though.
Old Apr 4, 2013 | 09:32 PM
Corvette40's Avatar
Corvette40
Just hollowed my precats out when they broke apart, it won't throw a code. I did eventually replace them to pass smog, didn't notice a difference.
Old Apr 4, 2013 | 10:24 PM
chillin-n-killen
Default cat removal
so it would be okay to remove them completely ??
Old Apr 4, 2013 | 10:31 PM
bjankuski's Avatar
bjankuski
Yes
Old Apr 5, 2013 | 01:05 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Good info for those considering breaking the law
Old Apr 5, 2013 | 08:29 AM
rithsleeper's Avatar
rithsleeper
Take your mufflers off while you are under there. It will put a smile on your face quickly. Then after a week you will want them back on...
JackDidley's Avatar
JackDidley
Mine fell apart years ago. I would not have gutted them if they had not but, they did fall apart. Now I have long tubes and an empty main cat. Not smog testing here.
Old Apr 5, 2013 | 01:13 PM
Old Ben's Avatar
Old Ben
2017 C6 of Year Finalist
Had the same problem with my cats and decided too remove them. Replacing them with straight pipes will increase exhaust sound but does little for adding power.
To cat removal
