Collapsed lifter
Old Apr 5, 2013 | 06:49 PM
The Bus's Avatar
The Bus
Default Collapsed lifter
I have just assembled the engine recently. I haven't driven it at all. It sounds like a old 283 with a bad lifter. Is there any thing that can be put in the oil which would cause the lifter to fill with oil again or do I need to pull the engine apart again?? I readjusted the valves three times to be sure they are set correctly. Can I play with the adjustment with the engine running to see if the lifter can be made to fill with oil?? Not really sure if that is the problem but I don't know what else it would be.
Old Apr 5, 2013 | 07:35 PM
aboatguy's Avatar
aboatguy
If you've readjusted the valves three times and its still tapping somethings up.
How did you adjust the valves?
Have you pulled the valve covers IOT see if one of the rocker nuts is loose?
New lifters or reused?
What year is the engine (is it flat tappet or roller)?
If Flat tappet did you use a good break in lubricant with the oil and the proper break in procedure?
If flat tappet did you reuse them?
MIke
Old Apr 5, 2013 | 07:43 PM
The Bus's Avatar
The Bus
It's a roller rocker and I reused the lifters.
Old Apr 5, 2013 | 07:47 PM
The Bus's Avatar
The Bus
Adjusted valves without engine running. Adjusted till the pushrod was against the rocker arm and was just able to turn it then I tighten it 1/2 a turn more.
Old Apr 5, 2013 | 08:17 PM
C409's Avatar
C409
..... Before you start it up back each adjusting nut off one full turn ... then adjust the valves while running by backing the nuts off one at a time til you hear it ticking then down til it just stops ticking and then another 1/2 turn down ...... when adding that half turn go slowly or it might cause the engine to stall ......... I think you went too tight with the pushrod turning method .......
Old Apr 5, 2013 | 09:16 PM
The Bus's Avatar
The Bus
THANKS C409
I'll give it a try tomorrow.
Old Apr 5, 2013 | 10:51 PM
mtwoolford's Avatar
mtwoolford
Originally Posted by C409
........... I think you went too tight with the pushrod turning method .......
I agree. It's easily done.
Make sure the valve you are adjusting is on the base circle of the cam...in other words the pushrod will be as far down as it can go.
Now back of the rocker arm until you are certain that there is no contact with the push rod; spin the push rod between your fingertips, it should spin easily, freely and without any perceived reistance; now carefully, slowly tighten down the adjusting nut of the rocker you are adjusting until the rocker just touches the push rod; at this point you will feel the SLIGHTEST amount of resistance to the previously free spinning push rod. You are now at zero lash , continue to tighten down on the radjusting nut any where from 1/4 to 3/4 turn depending on your own personal preference.
Repeat 15 more times.
Old Apr 5, 2013 | 10:53 PM
mtwoolford's Avatar
mtwoolford
[QUOTE= Adjusted till the pushrod was against the rocker arm and was just able to turn it then I tighten it 1/2 a turn more.[/QUOTE]
Way, Way too tight.
Old Apr 5, 2013 | 11:04 PM
mtwoolford's Avatar
mtwoolford
At this point, the lifters have little, if any oil in them, but don't worry. Expect some clatter on initial start up but if they have been properly (re)adjusted they will fill with oil and the noise should disappear after the first few minutes of operation. One clue: oil should begin to squirt out of the pushrod into the rocker arm.
Old Apr 6, 2013 | 12:44 AM
aboatguy's Avatar
aboatguy
Looks like you may be too tight... I'd bet I'd collapse a lifter before I'd get to the point where I was just able to turn the push rod
Mike
Old Apr 6, 2013 | 12:46 AM
aboatguy's Avatar
aboatguy
Now that I read the entire thread looks like everyone is in concurrence.
Old Apr 6, 2013 | 07:43 AM
WW7's Avatar
WW7
If doing a cold adjustment, something that works better for some people is instead of spinning the pushrod to get zero lash, move the pushrod up and down until there is zero lash. I find this stops the problem of over adjusting the lash.. Another thing you may want to do is back all the nuts off a little while before adjusting the rockers, this allows the springs in the lifters to fully expand so your not adjusting a partially compressed lifter...You also may want to check the Factory Service Manual to see what the actual adjustment should be. My 89 is suppose to have one full turn on the factory lifters after zero lash.......WW
Old Apr 6, 2013 | 12:47 PM
STL94LT1's Avatar
STL94LT1
Old Apr 6, 2013 | 01:29 PM
383vett's Avatar
383vett
An exhaust manifold leak can sound like a bad lifter. Are you sure the valves are closed on the cylinders when you adjust the lifters?
Old Apr 8, 2013 | 01:34 PM
HuskerBullet's Avatar
HuskerBullet
Default Valve Lash
Hey guys, if you ever need to adjust your valve lashes again, I got a tool from this website that really helps you to do that. It's just a magnetic vinyl strip with graphics that wraps around your harmonic balancer that shows each valve to be adjusted.
I've used this on my C6 after I replaced the OEM rockers with a set of 1.85:1 rollers and it works perfectly. Started up immediately, ran smoothly, and no noise, and didn't have to do a "fine tune" of readjustment or whatever later on. Anyway, just thought I'd mention that.
Old Apr 8, 2013 | 01:54 PM
ghoastrider1's Avatar
ghoastrider1
I have used both methods. Running the engine is a easy way to tell because when you back off (slowly)the lifter, you will certainly hear it change pitch and go to clattering. I tighten (slowly) until the clatter stops, then 1/2 turn more..slowly.
To Collapsed lifter
