code 31 33 35 37
Old Apr 7, 2013 | 09:53 AM
kito's Avatar
kito
8th Gear
Default code 31 33 35 37
I looked up the codes but i don t undetstand exactly what they mean never seen the codes before opti swap and i noticed when cranking my volts go down to 8 and cranks slowly took it to autozone they said i had low voltage on starter so does this mean i need a new starter
Old Apr 7, 2013 | 06:41 PM
vetteoz's Avatar
vetteoz
More likely your battery is flat , not being charged correctly by the Alt or just Kaput.
When cranking over, the starter sucks lots of power so if the battery is not 100% then there is no power left for the electronics.
Get the battery ( and Alt ) tested 1st before looking for other problems
Old Apr 7, 2013 | 07:39 PM
kito's Avatar
kito
8th Gear
I already got the batt and alt tested they tested good the only thing that came up was low voltage on starter well i guess i well start with new batt
Old Apr 7, 2013 | 09:19 PM
vetteoz's Avatar
vetteoz
Why if it tested good?
Dirty , broken or bad connections on the main battery cables can cause that condition
remove , clean and check both ends of those cables
To code 31 33 35 37
